Results 1 to 7 of 7
    Jun 2007
    guys, tanong ko lang kung anong puwedeng gawin para ma-resolve yung issue with the cd player. in dash cd player kenwood kdc 5010 ang model. pagka-insert ng cd (original or pirated cd-r and cd-rw) won't get played. parang binabasa lang for a few secs (around 10 secs siguro) then i-eeject din. ano kaya problema? maaayos pa kaya yun? TIA sa mga magrereply.
    Kenwood is known for weak lasers. {Ganundin yung sa Civic SiR ko.
    Jun 2007
    thanks marg. ano kayang magandang gawin? na-rerepair pa ba yun? or replace na?
    Jun 2009
    That could be repaired, optical lens due for replacement. That is the common problem of in-dash CD player whatever brand it is. Unlike separate CD changer which are more durable. My 6 year old, 6- disc CD changer( Clarion) is still functioning, no skips whatever discs (original, pirated) inserted. In case the cost of the optical lens is high, suggest you look for a separate Kenwood CD changer 6/12 discs, even slightly used in car accessories shop. I think your head unit has a provision for a separate CD changer.
    Apr 2010
    Quote Originally Posted by nickriingen View Post
    I also had a clarion CD changer but I decided to dismantle it and replaced it with a in-dash HU because, when in high temperatures, the CD may play, but it will skip and even not play at all. my CD changer also does not play burned CDs, that is why I get rid of my CD changer and get a new HU.
    BTW, aside from clarion, ano pa bang brands ang may CD changer?
    Jun 2007
    double double post post
    Jun 2007
    thanks nickriingen. anyone here knows where can the optical lens be repaired and its cost? even an estimate is highly appreciated. TIA
CD player won't play any CD
