Results 1 to 13 of 13
    :confused: :confused:
    hi tsikot peeps!
    Im a newbie here and also a newbie on audio stuffs. Tanong lng po ako kng saan ako mkalagay ng sub(s) for my ride.
    my ride: toyota hilux 98 ln166.
    my simple audio mods:
    pioneer deh-5550
    mb quart 2way seps and tweets up front - 216 ata ang model
    ryan audio seps sa rear
    ano ba best bet ko na lalagyan na subs, ano klase, size?
    may ngsuggest kse sakin na ung bazooka 6" bass tubes na amplified nlang daw kunin ko, pro parang kulang sakin eh.
    watchutink
    salamat pow
    sa bed ayaw mo lagyan?. hehehe
    dehins pwede pre.. lalagyan ng mga kagamitan eg.. sacks of cment,frtilizers and the likes also 4 light - medium trailing din sa probinsya. Another is security reasons..
    you can fit 8" subs sa rear back seats.
    I agree with sir ARB. You can fit 6" or 8" subs with customized box sa likod ng rear seats. Only downside is reduced storage space. You may also consider active tubular subs which is spacesaving like this one.
    http://www.pioneer.com.sg/products/c.../ts_wx105a.asp
    sir arb
    di ba naiiba ang angle ng recline sa seat? baka kse if i malaki ang box maiba ang seating position sa likod at pag medyo maliit nman bka di mganda tunog ng subs. =(
    Angled ang face ng box to conform with the seatback.
    may kakilala ako hilux perehos sayo. one 8" kicker comp vr, RF amp. Boston proseries 6" 2 way sa fronts, JVC mp3 na deck. the sub can be 2 8"but box specs not to manufacterers recommended. one 8" lang pala kaysa with the right specs. ok yung sound. thats the best that you can put na sub size.
    Jan 2003
    i sugest 8" Kicker solobaric L7. If your in the vicinity of manila go to intense sa manila. magaling yun!
    roydok, kasya ba yung mga tubular subs? pinatry ko minsan, di kasya sa ateng likuran. :D
    Jed, naka Tubular sub na si Roydok.
    sakwan daw!
    solobaric na 8" wont fit the hilux rear back seat.
    mga sirs thanks for the replies
    yung 2 rockford na 6" subs pwde kaya? ok ba 2nog? o should i settle nlang for bazooka bass tubes nlang 6s or 8s?
    i have pyle 8" powered tube i got a while back.. i used it sa ultra eagle..then transfered to my dearly disposed of f150 pero sympre tinanggal ko before selling.. ok naman siya..malakas din kaso dont expect na buong street ninyo maririnig..pero di na rin uso yung ganon masyadong 90's..if you want good bass inside your truck get the self amplified tube subs..pref 8s dont get pioneer tigas ng bass, pati yung jbls na maliliit, mahina naman.. sa backseat lang sya tapos sabihin mo sa installer na huwag permanent yung connection..dapat may connector para if ever may sasakay pwedeng maalis kaagad kasi it would take up some space... meron na ba dito yung blue na bazooka na mukhang nos?
help with audio
