Results 1 to 6 of 6
- Aug 2013
- 3
August 23rd, 2013 12:38 AM #1Good day to all!
need ko lang po ng help from you guys, since wala ako makitang thread about this kaya nag post na po ako, I'm currently in a project, its a '86 Benz 190E all manual, heres the catch:
-speaker front are at the dashboard and size 4" lang ata ang kasya sa kanya
-walang lagayan ng speakers sa mga door (deciding pa kng lalagyan at sacrifice ko yung sides ng pinto)
-may lagayan ng speaker sa 2nd row pero sa may ilalim ng salamin (any speker will fit)
-close ang likod sandalan ng 2nd row, you cannot access the trunk door thats why impossible sa subs sa likod
hope you guys can help me.
thanks in advance!
Modify message
August 23rd, 2013 01:22 AM #2
Most old school Merc's simply modified their door sidings to accommodate speakers.
When I was designing for a friend's Merc (https://www.facebook.com/photo.php?f...type=1&theater). I limited the "box" to around 1 cf sealed and it was a pain combing through files of midbass drivers that's available locally that is suitable for the box. I believe I settled on Dominations D8s (8" midbass) on the doors while the midrange and highs were handled by the Dominations F50 (2" widebander).
Okay, kung di mo ma-gets what I'm typing, it's cool. Just go to your installer and ask what your options are. However, you have quite a problem because you're pretty limited sa midbass ddrivers mo. You can't simply buy any run of the mill 5,000php speaker tpos salpakin mo lang siya sa DIY "box" because most midbass nowadays are designed for door applications/IB (salpak lang sila usually). So if you put speakers meant for doors in a box, you get two things: (1) it won't go as low and (2) it'll have a peaky response somewhere.
- Aug 2013
- 3
August 23rd, 2013 11:19 PM #3thanks for the reply jhnkvn. these dominations speakers how much sila nag cost? ok ba sila tumunog? i am planning to make it SQ kasi, since na hindi nmn pde mag sub. any suggestions kung san maganda mag pagawa? (not being bias pero need ko lang ng mapag kakatiwalaan na shop)
thanks sir!
August 24th, 2013 12:08 AM #4
- Aug 2013
- 3
August 26th, 2013 10:35 PM #5
August 27th, 2013 02:16 AM #6
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
