Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
    Feb 2012
    #21
    Yung brother ko dyan nagpakabit sa Growl Audio. Inabot ng 80k yata although may kasama nang headrest monitors. Yung Android HU ko nasa 23k lang kasama na kabit at TV Plus. Kagandahan sa Android mamili ka ng maps mo. I have Sygic, Osmand and Google maps installed... but I prefer to use Osmand. Mas detailed ang maps. Ang hirap lang mag-search ng location. Kapag ganun either Sygic or Google Maps ginagamit ko. Downside sa nabili ko is 1GB lang ang RAM. If you opt to buy an Android HU, don't settle for anything below 2GB RAM, kahit pa 256GB internal memory nyan.
    #22
    Yung sound reproduction ng Android HU ay di maganda as compared sa normal HU na well known brand na for music. I used yung android para sa monitor lang and still use the Pioneer para sa music.
    Name lang ata binbayadan sa Growl audio. Madaming mas magandang spec yung ibang Android HU.
    Dec 2007
    #23
    install mo adsp app sa android HU, if you know what you're doing, and be patient enough to play with the settings, you will be blown away kahit sa stock speakers. parametric equalizers are way better than graphic when tailoring sound.
    Mar 2018
    #24
    Quote Originally Posted by godwhacker View Post
    Hi Sir godwhacker,
    Meron po ba kayong recommended na specific aps relating to adsp? Nag try po ako maghanap and maraming lumabas na player and equalizer. Pacencia na po at newbie pa sa car audio. Tagal ko na din kase naghahanap ng equalizer na pwedeng gamitin sa android hu.
    Thanks po.
    Dec 2007
    #25
    Quote Originally Posted by G_man21 View Post
    Hi Sir godwhacker,
    Thanks po.
    look for "adsp" by Alexander Kasakevich . you may struggle at first for settings but there are defaults to chose from. i advice you to create your own or modify the defaults. add some more etc, etc..
    Mar 2018
    #26
    Thanks a lot sir. Will update you as soon as I have installed the apps you recommended.
    Have a nice day sir.
    Dec 2007
    #27
    let me know if you have difficulties i can send you screenshots of my settings i used with my bluedio T6. you will be amazed what adsp can do to a 32USD bluetooth over the ear headphones,.
    Dec 2018
    #28
    Quote Originally Posted by maksy View Post
    I used Polk Audio MM651 + Sound Magus. I left the rear stocked as I read from previous post of Sir John. Way better than stock audio.
    USB really takes sometime to read same with SD card. I think you need to give it a minute or two to read the cards. Comparing Sygic GPS vs INAV, mas masarap gamitin ang INAV kasi mas updated sila. This is based on my experience since I using both on my cars.
    How much did these things cost?
    I want a new display for my Honda and probably a bluetooth device foe music.
    I tried to look for Sygic Map update, I can't locate it. It will be better to coordinate with Growl on this matter.
    Jan 2012
    #29
    Mga katsikot just want to ask ano difference ng Growl Audio Android HU nila vs ibang android HU? Like yung inooffer ng Excellent Audio shop?
    Jan 2012
    #30
    Already back read. So if brand lang ang Growl Audio, do we have other Android HUs that you can suggest? Or shops who sell the best ones?
    Aug 2019
    #31
    Quote Originally Posted by carwhacko View Post
    android HU madami kang mabili just be carefull lang to choose. mine i bought it here in Singapore ts dinala ko sa Pinas for installation ok naman 2,32 GB. android HU. installation do it myself ala naman problema so far. all function works. if not mistaken growl is a brand of android HU what i unserstand they are installer. kaso may HU sila na binebenta so pag sa kanila ka mag pa install sa kanila ka rin bumili for my vios hey quote me 30k. i do it myself for 12k only same lang naman ang function sa android HU.
    #32
    Quote Originally Posted by wenz_vios 1.3 x View Post
    For 30k , mas mura joying 9 inches, 4G, 4/64 gb sa 27k with installation.
    #33
    Crutchfield....you can't go wrong w/ everything....from make/model-specific models of headunits to speakers, amps, trims, harnesses, mounts, adapters, etc. Reviews & DIY guidance...all there![emoji106]
    Note: The Vios marketed in NA. Some Yarises may share fitment.
    Aug 2019
    #34
    mine is already working.
    Aug 2019
    #35
    not even 20k then mas mataas pa nang specs sa quote nang taga growl for 30k.
Growl Audio vs others
