Results 1 to 10 of 25
July 2nd, 2009 01:32 AM #1
Can i achieve an SPL considered my system is about to be set-up is an SQL System? Or do i need to change sub boxes?
Kasi, i'm planning to get an SQL setup but i want to have an SPL without sacrificing the bass that we get from an SQL setup.
- Nov 2008
- 123
July 2nd, 2009 03:25 AM #2Sir..yong SPL na ibig mo sabihin ecompete mo yong set-up mo or want just a loud bass that will match to your front speakers? ano ang enclosure mo ngayon seald or ported?
tune or design your enclosure properly ma achieve mo yong goal mo and it will also sound great in low volume.. pero in SPL competetions and you want numbers(big score) on your certificate.. that would be another topic..LOL..
July 2nd, 2009 03:34 AM #3
AFAIK merong nanalo dati na naka SQ setup, not really sure though. pero alam ko naka sealed box un.
July 2nd, 2009 03:42 PM #4
I just want to achieve good deep non muddy bass with some SPL on it.
I'm planning to get a 1 or 2 pcs 12" kenwood with a sealed box. but i'm thinking if i should change it to a vented box and sacrifice half of my trunk. But after reading the posts in this section, most people who achieved SQL setup used sealed box. even who had previously have a vented box changed to sealed box and "never looked back"
and nope, i'm not entering any competitions since surely i'll fail hehehe...
- Nov 2008
- 123
July 2nd, 2009 06:23 PM #5Hi.. with seald you will still get loud bass(SPL) but it would not be deep bass bacause the seald enclosure will give a flat response.. you will acheive that with ported enclosure designs..single 12" would be enough in a proper enclosure..I have been to seald designs and then ported designs you can hear the difference...(especially if love deep bass)..
July 2nd, 2009 07:21 PM #6
July 3rd, 2009 06:16 AM #7
Lound and clear with SPL Hmnnn.. it can be done just know what is the best crossover points that you can get the most SPL on your SQL setup.
July 4th, 2009 01:00 PM #8
July 4th, 2009 03:31 PM #9
Loud and Clear = SQL most prefered by those who want to listen outside the car in a parking lot or tambay mode, yet attains certain SQ inside.
I heared soon there will be competition on this kind of category.. dati SQ at SPL lang ang pang compitition ngayon mayroon na "Loud and clear" ...
high idle RPM at engine start
