Results 1 to 19 of 19
    Sep 2006
    so wala talaga way para makapanood while engine is off. Hay.. ang gastos sa gas talaga..
    Quote Originally Posted by detailed View Post
    sa bahay na lang bro... mahirap din nyan baka ma taken at gunpoint ka pa.... seriously, i really do not recommend watching movies/listening to CDs while the engine is off. kung radio pa siguro, pwede-pwede pa dahil mahina ang consumption nyan.
    Sep 2006
    sige mga papi thanks sa reply. kala ko meron iba way para makapanood kahit off ang battery.
  4. #4
    Want to listen with your engine off? Get a deep cycle battery like Optima...
    think of it this way, yung matitipid mo sa gas, mapupunta pag pagpalit ng battery, so either way gagastos ka pa rin.
    Quote Originally Posted by ILuvDetailing View Post
    ganda logic mo fafa ah....
    --how much usually would the price difference of Optima and other batteries (like Outlast)? and when you say deep cycle, how long will the battery's charge last comparatively?
    Or better yet upgrade your battery to 2SM for longer entertainment time...but be sure na papalakihan mo din battery bay mo as it would not fit if you are switching from 1SM.
    --Also, if you change to a bigger battery (like 2SM from 1SM), would the alternator be able to sufficiently/properly charge the bigger battery?
    Sep 2006
    If I can remember it correctly, I've done this for more or less 45 mins. (CD playing/radio. Wala nman naging problema sa battery (less than a year old). I always turn my engine off while parked waiting, listening to the radio or using the CD player. OT:Excessive idling IS bad for your engine.
    Mar 2005
    If the battery is rated 40AH and your load is 5 amperes, you will have an 8hours play time before the battery is totally discharged. To be safe, you can have a playtime of 4 hours to reserve enough AH to start the engine. Remaining available Ampere-Hour rating of the battery decreases as it becomes older.
    Battery is considered totally discharged if the terminal voltage falls down to 10.5 Volts.
    Jul 2006
    Agreed. Was that the yellowtop? Deep cycle diba?
    Feb 2007
    would installing a capacitor for your sound system have an effect on running your sounds while the engine is off? I currently have a 1-farad installed and I can run my sounds at around an hour to one hour and a half. thanks. I;m just a newbie here. =)
  11. #11
    Quote Originally Posted by mbeige
    Yup Optima YellowTop.
    http://www.optimabatteries.com/publi...eep_cycle.html
    Quote Originally Posted by raphael_allen
    IMO its doesn't, your sound system will still draw current from your batteries.
Entertainment while engine is off
