Results 1 to 6 of 6
- Oct 2005
- 9
February 19th, 2006 06:28 PM #1good afternoon fellow tsikoteeers, tanong ko lang sana kung ano kaya pwede ko gawing solusyon sa engine and whining sound sa speaker ko, nagsimula lang ito nung magkabit ako ng amp. pero sa speaker lang na dinadrive ng amp maririnig ung tunog ng makina which is the rear speakers, pero sa harap wala naman, sana matulungan nyo ako, thanks in advance and more power
February 19th, 2006 08:18 PM #2
hmmm baka pwede mo lagyan ng choke(ferrite ring) yung power line ng amps mo?
February 19th, 2006 08:27 PM #3
ground loop isolator? no need for that.
balikan mo lang wirings mo. dapat walang nag co-cross na power wire sa signal wires. .
March 3rd, 2006 05:00 PM #5
yep...mukhang grounding nga yan...nangyari na sa amin yan nung colt mirage pa ang car namin...parang MRT. may humuhuni. dinala namin sa rey auto electrical... ayun, naayos din...tinanong namin yung culprit, kulang daw sa grounding.
March 3rd, 2006 05:31 PM #6
Probable causes:
- Poor ground connection
- Magkadikit ang RCA and power cables
Check your wiring sir make sure that your RCA cables are seperate from your power cables, tignan mo din mga connections mo make sure they're secure.
