Results 1 to 11 of 11
    Jun 2006
    ask ko lang...
    Jul 2006
    You can't expect the subs, to act as supplemental propulsion units when the car is moving, and the trunk is open, now would you?
    Seriously, your only enemy is weight, and too much current draw. Get a separate dedicated battery for your system, a larger capacity alternator, thick gauge wiring for your new battery (preferably also get a deep cycle one) and a large enough fuse for your main line. As you can see, all that adds weight...
    Jun 2006
    i dont know if has something to do with my setup pansin ko kasi mas matagal at higher ang rpm bago magshift. matic me.
    May 2007
    It has nothing to do with your audio. Need to service your tranny.
    weight lang kalaban mo sa sounds. minsan mas gaganda flow ng kuryente kasi most likely mag upgrade ka ng ground wires saka big 3 pag nag sounds ka.
    Jun 2006
    additional weight sa car. amps, subs and box minsan mat deadening pa. Kinda like having an extra person sitting in the car at all times.
    Bigger concern is the electrical load. You may experience dimming lights, drained battery (if you listen with the engine off for long periods of time), static etc...
    Aug 2004
    like what others have said, weight is one factor that will affect your cars performance. then just make sure your wirings are properly installed. at dapat enough power supply ng car audio mo kasi if not mabilis kang maubusan ng battery supply.
    Apr 2008
    May effect din ba sa performance and battery
    kapag di gumagamit ng AMP? HU Powered only?
    For example:
    Nagpalit na po ng Separates sa Front and New Coaxials sa Rear.
    Aug 2007
    Quote Originally Posted by Onyl Ryan View Post
    For example:
    IMO wala po, ang epekto lang is sa set-up ng SQ mo. sa kin nga hindi rin naka-ampli ang seperates ko.
    Aug 2004
    walang effect yan sa performance and battery.
    hindi mo lang mailabas ang full potential ng speakers mo
    kasi walang amplifier.
    Aug 2004
    ooppppssss, sorry double post.
sound setup may effect ba sa car performance?
