Results 1 to 10 of 11
September 12th, 2008 05:09 PM #2
You can't expect the subs, to act as supplemental propulsion units when the car is moving, and the trunk is open, now would you?
Seriously, your only enemy is weight, and too much current draw. Get a separate dedicated battery for your system, a larger capacity alternator, thick gauge wiring for your new battery (preferably also get a deep cycle one) and a large enough fuse for your main line. As you can see, all that adds weight...
September 12th, 2008 05:57 PM #3
i dont know if has something to do with my setup pansin ko kasi mas matagal at higher ang rpm bago magshift. matic me.
September 13th, 2008 03:40 PM #5
weight lang kalaban mo sa sounds. minsan mas gaganda flow ng kuryente kasi most likely mag upgrade ka ng ground wires saka big 3 pag nag sounds ka.
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 13th, 2008 10:34 PM #6additional weight sa car. amps, subs and box minsan mat deadening pa. Kinda like having an extra person sitting in the car at all times.
Bigger concern is the electrical load. You may experience dimming lights, drained battery (if you listen with the engine off for long periods of time), static etc...
September 25th, 2008 11:53 AM #7
like what others have said, weight is one factor that will affect your cars performance. then just make sure your wirings are properly installed. at dapat enough power supply ng car audio mo kasi if not mabilis kang maubusan ng battery supply.
September 26th, 2008 09:42 AM #8
May effect din ba sa performance and battery
kapag di gumagamit ng AMP? HU Powered only?
For example:
Nagpalit na po ng Separates sa Front and New Coaxials sa Rear.
September 26th, 2008 10:08 AM #9
September 26th, 2008 01:25 PM #10
walang effect yan sa performance and battery.
hindi mo lang mailabas ang full potential ng speakers mo
kasi walang amplifier.
