sirs/ma'am's i'm planning to upgrade my set up. current as of now is:
2sets mb quart coax eka-113 (powered by rf p450.4)
1 rf p3sd412 shallow series sub (powered by p450.4 bridged 225w/ch*4ohms)
Sub enclosure ported, pvc 4"x12", h=16, w=32, d=10" , 3/4mdf
1 1farad ground zero cap
1 stock hu (jvc kd avx1)
1 battery (stock 1sn lang yata iyun)
upgrade:
* additional dls separates for the front (this will surely be done due to add rear fill for the passenger (my daughter) while watching dvd)
upgrade choices:
1. sound deadening & change of enclosure for the current sub (p3sd412) & cd changer
2. sub system upgrade (additional 1pcs p3sd412, enlclosure for the 2 p3s, rf T10001bd to power the 2pcs p3s)
iyung po palang sinasabi kong rear fill is iyung nasa coax na nasa front is ilalagay sa may passenger and iyung new dls seps is sa harap ilalagay. and iyung ilalagay na mb coax sa may passenger is to be powered by kicker ix254 (old kicker impulse amp series) bridged to 65rms.
and lastly sirs/maam's, if possible, may i have a suggestion as to the design, dimension and materials (3/4 or 1"mdf) for the enclosure for one p3sd412.
please kindly help me in deciding, mahilig lang po sa sounds pero hindi naman po sumasali sa mga contest. which of the two would you recommend? practical po ba? thank you in advance.
suggest ko po, sound deadening. malaki po improvement nyan.
, sorry ) i really can't sacrifice much of my space because sometimes i'm loading my car with motorcycle tires up to the ceiling! (my car is a isuzu sportivo 2007, philipine version)
