Results 1 to 6 of 6
    Feb 2006
    mga sir ,
    sorry po sa medyo Stupe n tanong h?
    ano po kaya difff ng 2?ano po ba maganda n ilagay n speaker sa may pinto ng kotse?
    pag dual cone b dpat me kapartner pa sya?tweeter?whereas pag 2 way n speaker n lng kaya ikabit ko?simpleng stock setup lng muna sana.
    me luma n ksing 6x9 dun s likd , pwede n kya muna to ?para lng me konti sounds lng na mpapaknggan habang nagdadrive.
    salamat po sa inputs
    Oct 2007
    first of all, please do away with the text speak kasi ang hirap basahin.
    anyway, get seperate speakers (dual cone as you refer to) rather than coaxial speakers (2-way speakers you refer to). they sound much better, better midbass response and humming tweets.
    Feb 2006
    sorry po pala sa text speak mga sir,
    anyway pag yung dual cone po di ba kailangan pa nya ng separate na tweeters ?mid range?
    pag naman po 2 way is incorporated na yung tweeter dun mismo sa ibabaw ng cone?tama po ba?
    napansin ko kasi dun sa lumang speaker na nakakabit sa side ng ride ko is parang dual cone lang yata !nung nabili ko kasi ride e 2nd hand lang sir tapos di na gumagana yung speaker sa side kaya yun muna balak ko palitan.
    so naiisip ko kung 2 way ba o dual cone pa rin ikakabit ko dun?
    salamat po uli sa inputs mga sir
    Sep 2005
    2-Way, Component/Seperate Speakers - The low's go to the bigger speaker, while the high's go to the smaller speaker.
    2-Way, Coaxial Speakers - Still has two speakers for the high's and low's, but both speakers are mounted coaxially.
    Dual Cone Speakers - A single-way speaker with two cones to handle the high's and low's.
    It's best to use component/seperates as door speakers. Most speaker locations are set low on the door that you might complain hearing the high's when you use a 2-way coaxial or dual cone - because high frequencies are directional. With a component, you can put the tweeter on a higher or better location.
    Feb 2006
    ayos nadale rin sir,ehehehe
    anliwanag ng pagkakexplain nun !madaming madaming salamat po talaga sir StraightSix
    salamat po uli sa lahat ng inputs
    Aug 2006
    Very well said!!!
    nice StraightSix :clap:
Difference ng 2 way speakers at Dual Cone?
