Results 1 to 11 of 11
    Aug 2007
    im driving a new mazda 3 and gusto ko sana iset-up yung sound system ko ng spl. pero gusto ko rin na may trunk space pa ko. anong set-up ba ang gagawin ko? thanks.
    Jun 2007
    ported box tol with tamang tono!
    or abc rin kung targa
    Aug 2007
    sir, ano ba yung ported box? ilang subwoofer yun? at san lalagay yung amplifier? magagamit ko pa ba yung space para sa space tire? sorry. newbie lang eh. hehehe. thanks.
    Jul 2006
    For SPL audio setups specially for high power Subs (e.g., Solobaric L7), you need almost the trunk space available but again, not all SPL subs are solobaric-esque. Anyway, for ported box, this isn't enclosed fully and there are "exit points or holes". Ported Box are good for HP Subs to maximize its capability and allow you to have the "gapang" effect.
    Take note that SPL setups doesn't really require you to have an alloted number of subs. The bass effect will be affected by the box volume, the power of the subs, amplifiers, proper blending and mixing of the equalizer of the HU, etc. etc.
    I think Mazda3s use donut tires as spares so its easier for you to "hide" your spare and maximize you trunk sir.
    HTH!
    Try asking for sir Jeff Tan of ACA, he knows his 'Thang!
    Aug 2007
    thanks, sir. pano ko macocontact si sir jeff tan. any contact numbers, emails, address, etc.thanks ulet.
    may ma-rerecommend ba kayung set-up?
    e.g. brand ng ampli, sub, speakers, etc. balak ko kasi gamitin yung stock na hu eh. thanks
    Jul 2006
    Quote Originally Posted by onewingedangel View Post
    his from ACA near Arlington in Araneta, his works are highly recommended from a known car club.
    Try also going to KAC site. You'll learn lots of things there.
    Brands? for SPL, try going for Kicker, JBL, JL and Rockford Fosgate if you prefer known brands. Just be sure to have an audition of each sub you're choosing so to match what you really like. I'm a kicker and RF user so definitely I'll recommend both these two to you. Try going for Kicker L5, L7 or the new SoloX series; RF Power Series or the Previous HX Series too. Though these subs + the whole system (amplifiers, cap banks, wires, etc.) will cost you an arm.
    Also, don't forget to upgrade you're battery (if still casa provided) not all 1sm batteries can withstand high power requirement from the system you'll be loading it. Choose deep cycle batteries like AC Delco (expensive too).
    HTH!
    Aug 2007
    thanks sir. kung ang gagamitin ko ay stock na hu ng 2007 mazda 3 (di ko alam kung anong brand nun eh), tapos
    amplifier Kicker ZX 350.4 ( 4 channel )
    subwoofer Kicker CVR12 (800 watts) (ok na ba ang isa?) o isang CVR15 (1000watts) ang mas ok?
    yung speakers ba ay pwedeng stock?
    ok na kaya ang tunog nito? rinig na ba sa labas pag dumadaan?
    thanks sir. kung may marerecommend kang set-up for minimal trunk space lang ang makukuha, pasabi naman. it will really help me alot. thanks ulet. kudos to you sir.
    Jun 2007
    bitin yan ata alam ko 400 rms ang CVR12 e tpos yung kicker ZX 350.4 350 e
    bale di siya match, maganda sa kicker ang mga 2 channel amp or mono amp para talagang sulit ang bayo, in your case mga 400 w ratings pataas kung dedicated lang sa sub, pede rin diyan ung murang mura na v12 yung 800 w rating niya kung wala masyadong budget
    IMO mas maganda aftermarket na speakers ibang klase talaga ang tunog (mapapansin mo ito)
    sa HU pede naman siguro gamitin mo nalang yung dati, pero mas maganda talagang palitan ng aftermarket kasi para malinis ang tunog, kung may budget ka naman at ayaw mo palitan yung HU mo try search yung JL stuff na nagpapalinis ng tunog, yun nga lang presyong bagong HU
    HTH try to ask din sa mga gurus, sa kanila ko rin nalaman ito e
    Feb 2005
    Sir,
    Kung low budget ka, ported box na di-tanggal if you need space tapos 6x9 na pionner speakers on rear pero gastusan mo yung front seps mo para SPL. you need 2 ampli, 1 dedicated to subs na nakakabit sa box (pwede rin yung mga amplified subs with box) tapos v12 para sa seps and 6x9.at least kahit wala yung subs ay maganda pa rin tunog dahil may 6x9 ka.
    Jul 2006
    It depends on your budget sir, but if you extend it to at least 50k+ or more then it'll be alot easier for me to give you specs.
    CompVRs are usually setup-ed in pairs and check the RMS value first and not the peak, I think they go for 400W RMS on the 12" that are Dual voice coil (DVC). They produce almost spl-level when max-ed out but not really into spl., they are best performers when the box is closed (no ports) IMO. This way, accuracy will be maximized.
    Try going out for a 12" compVX subwoofer, you only need one sub that can produce SPL like bass but pretty much expensive, comes at a whooping 750W RMS and 1,500W peak at 12", 2 ohms DVC impedance, it comes best on a ported box that compliments with the box volume specification. Best bet, try auditioning different brands too at different shops.
    Box isn't that big too with the CVX.
    Else, if you want "basic" spl subs, go for Rockford Fosgate HX 12" it gives out 600W RMS, pretty much for those who have midrange budget.
    Also, beware of cheap immitation.
    HTH!
    Last edited by erickdpogi; August 30th, 2007 at 09:33 AM. Reason: add another info.
    Aug 2006
    mag JBL GT601.1 Class D Mono Amp.ka nalang 600rms x 1 alalay lang sa gain ng amp
    and for the seps try the crystals and power it by a jbl75.4II or a DLS CA41!!!
    dont forget to deaden your doors and trunk to prevent the rattles:rainbow:
    i think this can cost you at around 50 to 60k though you can buy it in second hand
spl sound set-up (minimal trunk space)
