hi ive just recently install a 7450mp on my car and i noticed that there was still some hiss on my mb quartz seps
nang galing po ako sa cassette dati so nasanay ako na may hiss... pero now that its cd based diba wala na po sya dapat hiss???
help i need help kasi i spent so much on it parang di tama na may hiss parin yung setup
-7450mp
-dsc216 mbquarts seps front
-comp series mb quarts rear yung may box na passive cross over
-stock wiring
kung papa upgrade ko po ba yung wiring ko sa tining nyo mawawala yung hiss?
silentmax,
had the same setup (7450MP, DSC216) a few weeks back. same problem with the woofer. sobrang tunog lata! :evil: was thinking about looking for passive x-overs for them, but before i started experimenting, my pair of RC61s at home were freed up, so yun na ang nakakabit.
didn't experience the hissing sound though. what i experienced, however, a little humming when the stereo was turned up and while the it was reading the next track.
the DSCs are at home, waiting for a solution. pls. post if the passive x-overs helped.
dami yan pwede panggalingan... if you haven't visited a shop to check your power/ground wires and speaker connections, try checking the settings on your head unit. For starters you can set the eq on your HU to flat. Lower the values or turn off HPF built-in crossover. Turn off Loudness. Try playing original SQ CDs with good accoustics, male/female voices. Try to avoid pirated CDs and MP3s for the meantime. At least by doing this, you can eliminate this source and make troubleshooting easier. :mrgreen: If the hiss is still very strong, maybe it's time to visit a shop or go back to who installed your HU and speakers.
Neilsen,
tried the same set of MBs (DSC 216). if you call the 1.5-2" tube-shaped apparatus per speaker the x-over, then meron. although, feeling ko, para lang yun sa tweeters. sadly, la syang kasamang rectangular x-over like that in the Q-series. the tweets are ok, in my not-expert-layman opinion, but the midbass, talagang tunog lata.
Glenn10,
they might help improve the sound quality a bit, considering la sya talagang "real" x-over. hindi mabuo-buo yung tunog ng midbass.
i also have the MB DSC-216 installed in my revo, i don't have any hissing problem. try to sample din other cds coz i've tried some cds na talagang malakas ang hiss from the recording. If at least one of your cds does not have any hiss when you play it then hindi galing ito sa seps mo.
I agree with Glenn, Having passive x-overs may not be the solution to your problem. Only Frequency response that are lower than what the tweeters can handle will be filtered by the passive crossovers maiiwan pa din yung hiss sound.
With regards to the "Tunog Lata" baka it's because your seps are not amplified yet.
Per specs ng 216 50-120 watts siya so RMS would be around 60w. I'm using 2 channels of my Alpine V12 MRV-f705 giving out 60-70w rms per channel to power my seps. mabubuo ang tunog nito but don't expect deep bass sound from it but definitely yung midbass response nya would be better coz you'll be giving it more juice compared to the one produced by your HU.
Refer to the response of zhero with regards to your HU. If it's set at high pass mabibitin ka nga sa Midbass kse the low freqs are filtered by your HU.
that may be the case......try amplifying the seps......then if you can.....try to salvage any passive xover and plug it in......just experiment on it until the hissing sound dissapears...:D
leon275,
i've tested them without the HPF. the thing with the HPF on, at least hindi sabog kahit ala masyadong bass. when i turned the HPF off, me bass pero medyo sabog. the levels of the Eq and the bass were quite low.
anyway, maybe the addition of an amp can improve the sound quality. thanks!
try mo munang humiram ng passive xover then test mo kung mawawala yung hissing sound.........if worse comes to worse.......better get another one para walang sakit sa ulo......:D
