Results 1 to 9 of 9
    Oct 2009
    magtatanong lang po ako regarding s use ng 2 farrad capacitor sa sound system natin? thanks.
    Capacitors
    Capacitors are used in most electronic products, and it’s common to see many
    of them populating a circuit board. These cylindrical devices store power the
    way a reservoir stores water. So when a circuit needs a bit of juice, the cap
    releases it. A capacitor is able to deliver power more rapidly than the car’s
    charging system because the power capacitor has a lower internal resistance,
    which allows it to quickly discharge.
    In the early 1990s, car audio sound-off competitors started adding large capacitors
    to their sound systems to provide instantaneous power when peaks in a
    musical passage demanded it. Before long, car audio-specific capacitors
    became available to the masses, and now they are a common sight in most
    high-end systems.
    You probably don’t need a capacitor if you have a modest system without a
    subwoofer, but you could probably use one if your system includes at least
    one subwoofer. If you have several amplifiers and multiple subwoofers,
    adding a cap or two can definitely improve your system’s performance.
    Whether you need a capacitor also depends on how much current your
    amplifiers draw from the vehicle’s charging system as well as the type of
    music you listen to. If you primarily listen to bass-heavy rap music and your headlights dim every time your system hits a bass note because of the strain
    on your car’s charging system, a capacitor could help. (You should also have
    your car’s electrical system checked to make sure it’s up to snuff, however.)
    Or if you think the total current draw of all of the amplifiers in your system
    starts to exceed the capacity of your car’s alternator, you’ll probably want to
    add a cap.
    Source: Car Audio for Dummies
    Publisher: Wiley Publishing, Inc
    Author: Doug Newcomb
    Page: 227-230
    Copy-Paste lang bro.
    Last edited by robot.sonic; September 29th, 2010 at 11:48 AM. Reason: Added the Source and other details
    Oct 2009
    thanks bro. yan pala ang use ng capacitor. important pala kapag may sound system ka. thanks =)
    Depende ata yan bro sa bigat ng system.
    Madalas gumagamit nyan yung mga boom boom cars. Humihigop kasi ng juice yung bass. Kaya kailangan nila ng extra juice. Kung di naman dumidilim ang headlight mo pag nagpapatugtog ka, palagay ko di kailangan ng cap.
    May 2010
    Quote Originally Posted by robot.sonic View Post
    kailangan mo yan sir lalu na pag ang amplifier mo ay 2000w pataas ang power
    1500w na amplifier pababa kahit hindi na lagyan ng capacitor yan......
    tip ko lang sir.. kung 3000w pataas ang amplifier mo mas magandang gamtin mo na baterry ay 3sm battery....na nasa 60 to 90 ampere.....
    at kung ang alternator mo naman ay nasa 90ampere ang capacity ok na ang 2sm battery lng
    Quote Originally Posted by heaven rio's View Post
    not true. even if you have a 1000 watt amp but put that on to power 2 or more subs. you will need a capacitor. a capacitor does NOT provide continues power rather STORES excess power. this is for the bass hungry sound setup.
    the REAL function of a capacitor is to store unwanted or excess power then to be released when the sound system needs it.
    if you have that much power of an ampli and power hungry setup (electrical crossover, more defined seps, etc.), changing the alternator to 120amp and the BIG 3 up grade will help plus the capacitor to STORE power.
    sorry to keep on chasing your posts but i have to set the info right for the benefit of others.
capacitor
