Results 1 to 3 of 3
    im planning to use a S10L5
    yung specs nung box is for me to be able to get the spare tire is not enough for a ported configuration. however, it's more than enough for the seal config.
    is there really a diffrence between ported and seal? sabi kasi nila mas maganda daw talaga pag ported. if i decide to go for a sealed box would increasing the box volume make it sound better??
    max reco sealed is 1.0 cu ft...i can go as large as 1.4 cu ft. vs ported na 1.3 cu ft. max. the min reco for a ported is 1.25 cu ft.
    what would box spec would you recommend?? i cant sacrifice my spare tire kasi talaga. safety pa rin priority...thanks!
    ported!!!! pero baka kulangin yung volume. kasi yung airspace na 1.25 hindi kasama yung airspace ng port.
    astig
    excluded na yung port dun so yung 1.3 cu ft net volume na for the box. so ported pa rin ba?? kahit nasa bare minimum??
    follow-up...
    will fiber fill fix my problem if i go for ported?? para more than the 1.3 cu ft yung effect??
    thanks!
box size...please help!!!
