Results 1 to 18 of 18
    Nov 2006
    Suggestions lang mga audio experts kasi plan ko buy 15' na sub gusto ko yung lupet talag.may 1unit na kong RF T1000.BD mono isip pa ko ng sub kung MMats P3,Crystal X2 1600rms, L7 ,RF T2, DD3515 budget is 30K and suggest ng box din
    Feb 2005
    go for DD in a ported box.
    Nov 2006
    have an ideahow much yung 3515? san ba may shop na meron?
    Nov 2006
    Sa SUV ko pala balak ikabit
    Mar 2005
    Considering space limitation, i suggest closed box enclosure. Try if these brand/model are available:
    1. ROCKFORD Fosgate, type: P115S4, resonanace frequency *42.59 Hz with box volume= 2.832 cu.ft.
    2. MA AUDIO, type:SYW15K, resonance frequency *41.68Hz with box volume=1.639 cu.ft.
    may RF T2 kami dito 4 days used lang, hindi kaya ng alternator ng swift so pinalitan na lang. tamang tama sa amp mo with ported box.
    Mar 2005
    Quote Originally Posted by ARB View Post
    Bro, paano yung hindi kaya ng alternator ng Swift ang RF T2 nyo?
    Feb 2005
    Quote Originally Posted by ianne View Post
    try calling mickey's autosound. his contact number's on his website http://www.mickeysautosound.com
    the alternator cant keep up the juice with the power required by the amp from the batteries. the option is to replace alternator with a bigger one and additional battery but the owner said na wag na lang, made the set-up simplier na lang. it was his choice to put the big RF so ok lang sa kanya.
    Jan 2004
    mag dd ka na lng with phatbox ... try to visit
    www.kotseaudioclub.com
    Kicker Solobaric L7 on a ported box is also good.
    Nov 2006
    Any comments ba with crystal X2? 1600rms daw eh..im thinking of having 1 15'in pasok na box size should not exceed 54x17x16 kasi i already have amp rack sayang if babaguhin pa.
    Mar 2005
    If you have the following parameters (usually given by the manufacturer), I can help you decide for the optimum box volume (either closed or ported):
    Fs -free-air resonance
    Qt -total magnification factor
    Vas- equivalent air volume compliance
    Nov 2006
    Fs-23.5hz Qts-0.52 Vas-4.2 ported daw sir required for spl kasi sub na to. have knowledge of rear horn type na box?
    Mar 2005
    Based on the above parameters, it turned out the following:
    1. For optimum ported box, volume of 9.644 cu.ft. will have a box resonance frequency of 17.78 down to 15.26, which you can't almost hear it anymore. As a compromise, try 4.2 cu.ft, which will give you a resonance frequency of 23.5 hz. If you don't have the instrument to test this frequency, it will be hard for you to decide for the port dimension.
    2. For optimum closed box, volume of 4.95 cu.ft. will give you an optimum box resonance frequency of 31.95 hz. (I preferred this one).
    If you want a harder bass, go for 2.177 cu.ft with a resonance frequency of 40.22 hz.
    Volume is the net volume. Approximately add an additional 10% volume to compensate the volume covered by your drivers.
    Horn type box are designed for external use like open space. I don't advise this for car application.
    Nov 2006
    ok,sir medyo mahina po ako sa frequency(hz) any suggestion kung san makakatulong sakin sa pag gawa ng box or shop? may setup na po kasi ako and gusto ko lang yung boy lang ng subs ang mabago at wag na amp rack,wala pa po kasing 1month setup ko and now lang talaga ako naka pagdecide. i'll post pics some other time so you can give me guys suggestion on what i can do.tnx po pala sa oras
    meron nagbebenta ng dd3515d with ported box sa kotseaudioclub.com. look for paul ferrer. 20k ata niya benta. gawa ni mickey yung box.
    naka audi ako ng 3512d + t1000 lakas din!!
    Nov 2006
    pepengtom-have you auditioned mmats P3 15'? sin lakas kaya nun?my na auditioned ako DD but ay dont know the model pero malakas din pwede credit card?hehe
boombastic sub size 15 help
