Results 1 to 3 of 3
- Jan 2004
- 8
January 6th, 2004 03:12 PM #1between Lanzar and Crunch amps, ano ang mas maganda?
im eyeing either one of these, the Lanzar Vibe 438 and the Crunch BlackMaxx BLX4175.
tsaka patanong na din po kung meron mabibilhan ng mga ganitong mga amp dito sa pinas?
salamat
- Jan 2004
- 121
February 26th, 2004 06:26 PM #2Both are good. I remember seeing Lanzar AMPS sa concorde megamall. Pls. check na lang. Thanks
March 12th, 2004 07:43 AM #3
If those two have the same prices
You might want to compare quick stats here at these sites
http://www.lanzar.com/itempage.asp?model=VIBE438
http://www.maxxsonics.com/crunch/frame_amps.html
Although the best comparison is to have a head to head audition using the same setup powered by two different AMPS by YOU. Iba iba kasi gusto natin... Given that this is close to impossible here... I'd go for the Crunch as far as looks go.
Medyo weakling presentation ng Lanzar, but that's really a far out suggestion... power, sound clarity and fatures hanap natin dito.
Hope those sites help, another thing is to check how much they both go for on the same on-line stores....
high idle RPM at engine start
