Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Apr 2008
    mga audio wizardz, patulong naman. i have a HU n JVC KD S585 kaso alang aux in, pede bang palagyan ito? salamat po!
    Apr 2008
    bro, alam ko sa banawe 1k lang!lalagyan ata nila ng wire ung HU mo tapos lalabas sa ilalim ng dash. kinda weird but it works!
    hahaha tama po, yung mga ganyan, kaya talaga lagyan ng aux in for mp3 players. panget lang tignan but its the cheapest way to do it...
    Aug 2003
    seryoso toh?
    astig.
    pero, depende pa rin sa stereo right?
    stock ng honda idsi city..pde nito?
    Apr 2008
    not sure if pwede sya sa lahat ng stereos sir. but better go to banawe to be sure. yung sa friend ko kasi pioneer na walang aux so pinalagyan nya. ako i decided to buy a belkin fm transmitter which caused me about 5k in damage!ung sa friend ko 1k lang.but masmalinaw ung sounds nung sa kanya. ung sakin kasi parang fm lang ang quality ung sa kanya talagang clear!ganda sa sound set up. i think pwede mo din itrade ung luma mong stereo para palitan nila ng player na my aux!
    Quote Originally Posted by winferrer View Post
    seryoso toh?
    astig.
    It should work for all types of stereos, bro.
    They will tap it right after the pre-amp.
    Enjoy!
    5909:burn:
    the cheapest is simply by using mp3 modulator, no modification. saksak mo lang siya sa cigarette lighter, then connect mo siya sa music player mo. actually puedeng isaksak ang usb flash disk at siya na mag play kaya lang you cannot arrange your music selection. FM radio wave ang pasok nya sa HU mo. around 500 petot lang gadget.
    Dec 2007
    Quote Originally Posted by valvura View Post
    Cheapest also means worst sound quality, especially at higher volumes.
    The whole point of the aux-in connection is to have a physical wire from the source to the receiver, so as not to lose any sound quality.
    Quote Originally Posted by Type 100 View Post
    yes, may type na bad sound quality but i got a good one na claro naman ang base & other sound frequencies at high volume, "wired" from modulator to mp3 player (directing USB flash mem is no good), same principle sa wireless microphones. any way, if you intend to tamper with the original design your HU by putting AUX in, better buy a unit with a built-in.
    fyi, i also drive a revo glx same with markuz14.
    Apr 2008
    wow good for you!ako kasi i bought a belkin pa na brand almost 5k!di ko mamaximize ang sound set up ko!parang bitin ung bass pagdating sa subs ko! fm na fm lang ang dating unlike if its really an aux in!i could really feel the bass thumping towards my chest and my rear view mirror ! using a fm modulator imho would just transmit your audio into a fm modulation frequency unlike using wires wherein there is a direct connection between your mp3 player and your HU. but its really way better i guess if you'll just buy a HU with mp3 capabilities.
    Dec 2007
    For your PhP5k Belkin you can have a number of decent HUs with aux-in capability already. Add a couple thousand and you can even plug in USB thumbdrives---something Pioneer seems to have specialized in for 2008.
    Pero kung masaya ka na sa FM modulator...doon ka.
    Apr 2008
    sir hindi nga po ako masaya sa fm modulator kaya recomend ko ung aux in. i bought mine nung gen1 pa ng mga ipod kaya wala pang aux in ang mga players. kasi pag fm modulator bitin unlike ng aux in.
    Dec 2007
    Aux In?
    what you should look into your HU:
    1. face - if there's a hole with an AUX IN label, then you have an AUX IN
    2. at the back - if there's a hole and looks suspiciously like an AUX IN, then chances are, it is an AUX IN. Get yourself a baby plug (stereo) to baby jack cord.
    3. at the back - if your HU is CD changer ready, then buy yourself an adaptor with one end that will fit into the CD changer socket and the other end would either be a pair of RCA or baby jack
    4. at the back - if one of the pairs of RCA dangling is labeled as AUX IN, then get yourself an RCA to baby jack cord.
    Some of the HU's are still needed to be configured to accommodate that AUX IN feature, otherwise and most of the time, it is just simply plug n play.
    FM Modulator is simply a device which modulates the signal coming from your audio device into radio frequency which in turn will be demodulated by your HU to cause it to be heard audibly through your car's audio system. In short, parang nakikinig ka lang talaga ng FM station.
    Hope this helps.
    Apr 2008
    wow! sa wakas napansin din ang aking munting katanungan... he he he.
    una po sa lahat ay nais kong pasalamatan lahat ng nagbigay ng oras at talento sa pagsagot!
    Pangalawa, san po maaring magpakabit ng aux in bukod sa banawe? from south kasi ako, mejo malayo. kaya na kaya po ng mga stereo technicians ang ganung set-up?
    salamat po!
    Aug 2003
    sa banawe? sino nag lalagay ng aux in from the back?
    thanks thanks..
    Aug 2003
    bad news..just called maspro banawe, ang hu ng city is fujitsu ten, 2500 ang singil pag magpapalagay ng aux in, tapos bubutasan sa harap, or 2nd bay ng radio.
    they will attach it daw sa connection for the cd shuttle.
    sa pioneer daw..mura lang...1k lang daw pag hu is pioneer.
    Apr 2008
    Quote Originally Posted by dok_nukem View Post
    with that much amount sir, i would've just opted for a new head unit, with aux-in and usb na...cd quality, and consider the kewl power it will pump thru your speakers...just ma five bucks
    Apr 2008
    Quote Originally Posted by markuz14 View Post
    salamat po!
    try evangelista in makati dami car shops jan, kid audio in binan, kartrix in binan, alabang, sucat and look for jun...hope it helps
    Apr 2008
    Apr 2008
    salamat sa mga inputs sir! makakatulong ito, anyways pag i isipan ko po. kasi ung HU ko e sira rin yung CD player... i might opt to buy a new 1 n lng. tnx mga gurus!
Aux In
