It was easy to just look to its rms power of both equipment.The power output of an amplifier should be roughly matched to what the amp will be used for and what speakers it will be driving. Oddly enough, the most common problem with matching speakers and amps is using an amp that is too weak to power the speaker. When an underpowered amp is used to power a speaker, the listener tends to turn the volume up higher in order to get more output of the amplifier. Eventually the amplifier runs into its limit and begins to distort. This distortion can cause the output from the amplifier to become DC for short periods of time and DC signals of even low power can destroy a speaker. Underpowering a speaker in this way can be more dangerous than overpowering it! Also more power is usually necessary when powering subwoofers because of their large size and excursion. Do not plan on using an amp of less than 75watts per channel to drive a subwoofer. The converse holds true for higher frequencies (midrange and treble) only 25-50watts per channel are necessary to drive speakers in those frequency ranges, however more power will not hurt, it just probably will not be used. Another factor in power output is stability in low resistance loads. Say the power output of the amp is 500watts rms * 2ohm stable, it says, these equipment can drive two subwoofers 250watts rms single 4 ohms. Sometimes you can wire multiple subwoofers to a single channel on an amplifier but the amp will have to work harder to drive this kind of load. Many moderately priced amps can drive loads as low as 2 ohms or less, with 4 ohms being the typical load of a single speaker.
