Results 1 to 12 of 12
  1. #1
    Guys,
    How do you eliminate audio static? Kasi I noticed that when i'm accelerating it seems there's audio static. medyo mahina pero i'm afraid it'll get worse....any suggestions?
    thanks,
    city
  2. #2
    do you have any aftermarket audio components installed? Better check the wiring and ground points, that might be the culprit.
    Dec 2003
    sometimes audio cables and power cables clumped together will cause that
  4. #4
    thanks for the replies guys.....san ba may magaling sa linyang ito?
    thanks,
    city
    Baka nasa ignition switch naka-tap yun power. Lipat mo sa accessory yun + supply niya. Try mo sa Wizzards.
  6. #6
    Thanks afrasay!...can i get the directions going to Wizzards...medyo unfamiliar pa ako sa mga shops e
    city
    Feb 2004
    in case you're in the qc, del monte area; i might be of some help to you.
  8. #8
    kewlryds...thanks for the offer....too bad i'm in alabang area.
    pano kaya
    stock sounds lang po ba?
  10. #10
    yes odell..it's a panasonic CX-Dp1205 for nissan exalta 2000 STA.
    Jan 2003
    lagayn mo ng relay yung positve (red wire) did it to my lancer pizza... tanggal ang static... na hindi kinaya ng noise supressor/filter...
  12. #12
    thanks impulzz! i'll keep you guys posted. any other suggestions?
Audio STATIC!!
