Results 1 to 7 of 7
    thanks for the info....
    May 2007
    See the speakers cut out opening on the back. If it is round, it wont fit you may have to cut it. Other option is you have to install the speakers at "bottom mount" not a "top mount".
    Nov 2007
    Quote Originally Posted by spadez60989 View Post
    I owned a 96SS before and I was able to install a pair of 6x9 speakers at it's rear dashboard, I think the 98 model has the same clearance and space with the 96 model so feel free to install your speakers.
    Sep 2005
    sir...round din ung butas sa dashboard ko sa likod. what i did para lumutang naglagay ako ng spacer 8x11 3/4 wood then binalutan ko ng black leather. . DIY lang po sir madali lang then bolt mo ung wood from the bottom.
    Mine has 6x9 speakers at the rear deck. It has a spacer to lift the speaker slightly so no cutting would be needed.
    Apr 2008
    Yun po ba yung tinatawag na "mount ring"?
    Saan po ba nakakabili nito aside from DIY?
    Kasi nakabili ako ng 6x9 pero di kasya sa rear kaya parang open siya.
    Apr 2009
    Hi having the same problem din. Been lurking here for a solution for a while.
    Bilog yung butas sa likod sa akin at 6x9 ang ilalagay..parang malabo na mag butas dahil dun sa spring ng trunk ay tatama sa magnet kung i center ng konti other wise walang way makabutas sa outer sides dahil sa bakal.
    Saan kaya makaka bili ng spacer na medyo angled like this:
    Ok ba yan kung meron (saan kaya) ? Parang corny kaya lang no choice, labo din from beneath kasi di kasya nga dun sa spring thing ng trunk
yung 6x9 speakers ba mgfi-fit ba sa likod ng 1998 SS sentra?
