Results 1 to 7 of 7
- Mar 2009
- 15
March 31st, 2009 04:07 AM #2
See the speakers cut out opening on the back. If it is round, it wont fit you may have to cut it. Other option is you have to install the speakers at "bottom mount" not a "top mount".
April 1st, 2009 08:08 AM #3
April 9th, 2009 07:09 AM #4
sir...round din ung butas sa dashboard ko sa likod. what i did para lumutang naglagay ako ng spacer 8x11 3/4 wood then binalutan ko ng black leather. . DIY lang po sir madali lang then bolt mo ung wood from the bottom.
April 9th, 2009 07:49 AM #5
Mine has 6x9 speakers at the rear deck. It has a spacer to lift the speaker slightly so no cutting would be needed.
April 18th, 2009 11:20 PM #6
- Apr 2009
- 3
July 19th, 2009 03:02 PM #7Hi having the same problem din. Been lurking here for a solution for a while.
Bilog yung butas sa likod sa akin at 6x9 ang ilalagay..parang malabo na mag butas dahil dun sa spring ng trunk ay tatama sa magnet kung i center ng konti other wise walang way makabutas sa outer sides dahil sa bakal.
Saan kaya makaka bili ng spacer na medyo angled like this:
Ok ba yan kung meron (saan kaya) ? Parang corny kaya lang no choice, labo din from beneath kasi di kasya nga dun sa spring thing ng trunk
And you can't opt out of the update.
National ID Law
