Results 1,911 to 1,920 of 3070
May 6th, 2016 02:34 PM #1911
Tanong mo sa seller if the more expensive type has a aluminum layer. Yun mga generic type like the acoustipad you mentioned does not have aluminum layer. Mas malinis at mas heat resistant ang mga butyl rubber type deadeing material that has a aluminum layer.
With regards on using the filters on your amp or HU. You neither use one of them since your speakers comes with passive filters already. Just turn off the HPF on the HU and set the the filters of the amp to off or all pass. If the amplifier does not come with the option of setting the filters to off or all pass, leave the settings to HPF.
May 7th, 2016 08:20 PM #1912
Yung Acoustipad may variant siya na may aluminum layer and meron yung all black lang na material. I chose yung may alumnum layer and consume 2.5 sheets per door.
Thanks, will try this later. Current setup ko is naka On HPF sa HU front and rear and naka All Pass sa Amplifier. Front seps ko pala is Focal PS 165F and Sound Magus C160 4 channel amp and pioneer coax for the rear.
- Mar 2009
- 71
May 7th, 2016 10:00 PM #1913what happens if you run an 8 ohm speaker with an amp with a 4 ohm output
May 7th, 2016 10:32 PM #1914
May 8th, 2016 11:35 AM #1915
May 8th, 2016 12:38 PM #1916
Thanks, will try this later. Current setup ko is naka On HPF sa HU front and rear and naka All Pass sa Amplifier. Front seps ko pala is Focal PS 165F and Sound Magus C160 4 channel amp and pioneer coax for the rear.[/QUOTE]
Yes bro try to notice the performance of the midbass after.
- Aug 2012
- 2,767
May 8th, 2016 01:34 PM #1917Speaker impedance is not fixed. It changes with frequency. An 8 ohm speaker may be 8 ohms now, but could change to 2 ohms in an instance and 16 ohms in another instance. Same goes with 4 ohms speakers.
Sent from my D5833 using TapatalkLast edited by red_one; May 8th, 2016 at 02:09 PM.
- Mar 2009
- 71
May 8th, 2016 10:41 PM #1918may negative effect po ba sa amp or speaker kapag ganun setup magkaiba ohms .... salamat
May 9th, 2016 10:14 AM #1919
May 13th, 2016 02:19 PM #1920
There's nothing wrong with a speaker being underpowered. What's dangerous is when you do the opposite -- overpowering (aka turning the volume knob as if you're trying for 180dB) as it leads to mechanical failures (ex. burnt coils, etc.)
What's dangerous is an uninformed person having a low-wattage amplifier. More often than not, he's turning the volume all the way up and then damaging the poor speaker in the process.
Imo at that price it becomes a very tempting buy even with its' flaws.
2021 Nissan Leaf
