Page 133 of 154 FirstFirst ... 3383123129130131132133134135136137143 ... LastLast
Results 2,641 to 2,660 of 3070
    #2641
    Quote Originally Posted by Sleepcare View Post
    Boss please clear your inbox.. hindi ko matuloy yung buyo session natin
    Cleared, sir!
    Thanks
    Dec 2010
    #2642
    need your help sirs and thank you in advance
    i just recently upgraded my audio setup
    from JBL gto509c seps ,Pioneer 295bt and no amplifier
    i got focal ps165f for seps
    hertz hcp 4 amplifier
    retained my pioneer 295bt
    the issue is, i hear pops from time to time
    the gain on my amp is at 11 oclock
    and my stereo is only at 50%
    galing sa old setup ko, i never experienced this
    although nagimprove yung quality ng highs
    medyo nakukulangan ako sa bass din
    really a noob and im trying to really read up on these matters
    pero malaking tulong ang opinion ninyo
    Oct 2008
    #2643
    Quote Originally Posted by remanthony View Post
    pops meaning some sort of distortion that seems to be coming from speakers being overdriven? probably you could upload a youtube video so the masters here can check.
    Dec 2010
    #2644
    Quote Originally Posted by artsky View Post
    i will try my best with the video sir since its really erratic ill do my best
    and the pop im describing is like a really harsh snare-like sound
    its frustrating
    thanks sir
    Aug 2009
    #2645
    Masyado mataas gain boss. Lower the dial and check wiring properly baka loose yung ground sa amplifier
    Mar 2012
    #2646
    Try to check your wiring connections or the terminations on your cable wires specially on the amps. Isang cause ng popping of speakers ay di magandang connection. Natatandaan ko yan na sound nung highschool kami sa diy project namin na amplifier/booster. Very crude ang pagkagawa at naka mount lang sa parang aluminum C-purlins. Parati ko naririnig yung pop pag switch on ko ng toggle switch.
    For gain settings I suggest the digital multi-meter method for accurate settings.
    Aug 2015
    #2647
    question mga masters...
    Planning to setup 2 stages ng audio upgrade... for now..
    (1) 4ch amp (70rms/ ch) 2xseps 2xcoax 1x12" 500rms sub (bridged)...
    next gastos
    (2) 1 mono, +1x12" sub(same)
    Tingin nyo po ba ok lng yng plan ko... wala ba magiging prob sa first stage? btw bago na HU ko.. Kenwood 417BT.
    Sent from my SM-N9005 using Tsikot Forums mobile app
    Sep 2006
    #2648
    Quote Originally Posted by rainybhoy View Post
    next gastos
    Anong sasakyan po, sir. Normally, mga recco is wag na iupgrade ang rear, normaly resr fill lang. in my case, tinanggal pa nga ang connection e.
    Aug 2015
    #2649
    mazda 3 sedan (2012 gen 1).
    ah talaga? magandang idea nga hehe..
    pero sa stage 2... since malilipat na sa mono yng sub... yng rear dun na sa dedicated channel... hndi kaya parang di balance.. malaki wattage ng front pero sa rear mahina?
    Dec 2010
    #2650
    mga master planning to add DSP ok ba ang SOUND MAGUS DSP T8
    http://www.soundmagus.com/prod_view....7&FId=t3:134:3
    Nov 2017
    #2651
    Question po..
    Meron akong 2x GTS12 JBL Sub at 1x Capacitor, ano kayang kelangan ko pa para masetup yung sound system ko?
    Hyundai Getz 1.1 2010
    Salamat po.
    Aug 2010
    #2652
    next gastos
    People who go for the SQ route won't put coax in their rear doors na. Sayang lang gastos.
    Don't base wattage equals performance and don't think na more wattage automatically means a louder speaker. Feeding 1W of power to a normal silk tweeter and a horn-loaded tweeter will yield drastically different results.
    For your 4 channel speaker, connect 1 and 2 to the front separates then bridge 3 and 4 for the subwoofer. Grabe yun original plan na front + rear on 1 & 2.
    Quote Originally Posted by armour07 View Post
    Yup. Go with what your installer recommends is a better idea tho. Since siya naman magtotono ng systema mo, better use an equipment na sanay na siya how to handle the interface, etc.
    Aug 2010
    #2653
    Quote Originally Posted by nerraw View Post
    Question po..
    Salamat po.
    Uhhh, you need power (an amplifier) to power those subwoofers at least. Kilangan mo rin ng wires to run power to them.
    Remember: Source (HU), wires, speakers, power source (either HU or amplifier depending on load). Ayan lang kilangan mo sa setup.
    Oh, sell your capacitor. Di yan gumagana.
    Aug 2015
    #2654
    Quote Originally Posted by jhnkvn View Post
    Aug 2015
    #2655
    may nabili ako good condition na Alpine MRP F600. Mdyo luma na pero mkhang solid. 300W rms x 2 bridged *4ohms.. so.. mkhang hndi kaya yng sa 500rms sub na plan ko... anung best setup kaya d2.. shall i go for mono na.. or settle for 300rms sub para sakto sa 4ch amp.?
    Dec 2010
    #2656
    *jhnkvn
    thanks sir mostly kc ng ginawa ko is DIY lang sir bale yun DSP ang end game ko budget set up lang ang kaya ko sir,
    ang problema wala masyado good installer d2 sa amin na may knowlwdge sa DSP.
    last time ko kc ginamit is 3 way electronic crossover but parang kulang sa staging/imaging.
    need more input only on DSP settings.
    nag lagay kc ako capacitor sa tweeter to protect it, do i need it also when i use a dsp?
    Aug 2010
    #2657
    *jhnkvn
    If then so, just go with the DSP then. It doesn't take a PhD degree to learn how to use its interface and a -1dB is also a -1dB on more expensive DSPs.
    For the DSP, the most important part is the output channels. Most DSPs for 2-ways costs 20K while the 3-way costs an additional 10K more. But they need not be expensive, miniDSP has been highly recommended by US car audio forum DIYMA for many years and that just costs like PHP5K-8K tops.
    In running a full active 3 way system, I will highly recommend a capacitor on the tweeter as protection. Just remember to set the value appropriately as it acts as a first-degree (or was that second) slope -- aka it acts like a -6db xover slope with the frequency depending on the capacitor value.
    Walang right or wrong sa tuning and getting the proper staging and imaging is pretty much the result of hard work. Many people start by doing sharp cutoffs and a low midbass cutoff (ex. 50/63hz on 2nd/4th octave) para nasa front yun imaging but ako nga I'm running with my midbass at a very high 100hz cutoff on 12dB slopes. Kanyang kayang tuning lang talaga yan.
    Aug 2010
    #2658
    1. Don't be too fixated on subwoofer power. Unless gusto mo talaga yun bumabayo sa labas, even 150W is enough to fill your car cabin with enough bass.
    2. If mag-mono ka, saan mo icoconnect front mo? Sa head unit? In that case you'll be too subwoofer happy. In a LnC setup that isn't that bad but SQ wise your front stage won't keep up sa bass mo.
    3. Go for the 4 channel and try mo muna. Kung kumulang ka, then you can just add the mono amplifier and have the 4-channel amplifier para sa front speakers (1 channel per driver)
    Dec 2010
    #2659
    *jhnkvn
    thanks sir for the input, perhaps i need to research more on google and youtube
    Aug 2015
    #2660
    Thnx sa advice jhnkvn..
    been watching a lot lately sa youtube.. and isa sa mga takeways... do it once.. do it right.. obviously.. cant do it once since magastos (for my budget) yng gsto ko 'standard' setup. kaya planning to have it in 2 installments. w/ d advtge of enjoying good sound sooner..
    but if i can get away w/o a mono and good enough bass.. kaya na cguro 1 gastos nlng ;-)
audio set-up for beginners [continued]
