Results 1 to 10 of 3070
Threaded View
March 7th, 2019 04:43 PM #10
"Mahal" is actually subjective when it comes to car audio.
Yung 40k sa labas vs 40k sa dealership actually differs a lot if you'll consider the added equipments that will be used.
For the "40k sa labas", you'll get the following:
-1 pair of 6.5" 2-way seperates (front)
-1 pair of 6.5" coaxials (rear)
-1 set speaker spacer (if needed)
-1 set of door deadening material (outer shell only)
-1 4-channel amplifier
-1 12" subwoofer
-Box for the subwoofer
-Wiring
-Labor
This set varies from shop to shop so better check your friendly car audio shop. Some might take out something and some might add something.
Personally if i were to build a simple system, ganito gagawin ko.
All prices are inflated and wiring/labor price is also an estimate:
Set 1 (underseat sub)
-1 pair of 6.5" 2-way seperates (front)- Pioneer * 5k
-1 set speaker spacer (if needed) * 1k
-Front door deadening (inner and outer shell) * 3k
-2 channel amplifier (powering the front speakers) * 5k
-underseat sub * 10k
-Wiring and labor * 5k
TOTAL - 29k so round off nalang natin to 30k
Set 2 (sealed box)
-4 channel amplifier (powering the front speakers) * 7k
-12" subwoofer Pioneer * 5k
-Subwoofer box * 2k
TOTAL - 28k round off nalang natin ulit to 30k
You'll get more bang for the buck sa set 2 but if may space constraints, set 1 should suffice.
When i read the bold part ng reply mo, i knew that it is only a setting problem. I need to know your wiring diagram sa amplifier before i'll give suggestions.
LOC gain dapat hindi ginagalaw yan. Dapat nasa gitna lang based on experience. Adjust the gain thru the amplifier only.
There is no perfect hpf/lpf setting kasi we're doing it in the worst environment to produce proper sound (car) so it varies from car to car and equipment to equipment.
Sorry, i can't help sa Cebu area kasi wala ako kilala doon. Nasa Dumaguete kasi yung kilala ko. I'll check with him for Cebu area.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
