Test if its worth to download or purchase flac and dsd files....
How Well Can You Hear Audio Quality? : The Record : NPR
Wav over flac over dsd.....
Too many factors to mention like how it was recorded, the equipments used to record the instrument, how it was mixed, mastered just to name a few. I came accross a wav file sounding like it was just a 96bit mp3 file. In a moving car environment, only 4 out of 10 can distinguished a 128bit mp3 file over a wav file.
Just my 2 cents as a long time sound engineer.![]()
Hello po mga Mobile Audio Guru. Ask lang po ako kung ano po ussually cause ng amp auto protect?
Set-up ko po is DLS P40, 10” Polk MM1 DVC, Focal Access 165 AS3 in a 2015 Subaru Forester.
Thanks In Advance.
Good day friends.
So I already sold my 2015 Altis including all SQ equipment installed. I will be getting a Wildtrak and contemplating on the equipment to be installed. I still like how the AP RAM sounds. Jonz suggested the RAM 1.6. Coming from the RAM 2.6 I think this is a good pick as it would also fit well with the Wildtrak's tweeter stock location. Any other alternatives that are comparable or better than the APs for the seps which costs around 20k to 40k? I listen mostly to jazz, pop and a bit of R&Bs.
Would also like to hear for any suggestions on DSPs for integration. Hard to replace the Wildtrak's HU due to sync3 issues and connectivity with the truck's other systems. I have seen the HELIX P6 dsp + amplifier which costs 60k+. Thinking probably getting a 4ch amp + stand alone dsp but would appreciate other inputs.
I can go sub less. But Jonz mentioned the Ryan Audio underseat subs. Meron ba sa atin may naka gamit or nakarining na nito?
Thank you guys
