Results 1 to 20 of 3070
    Thanks sir.
    Leaning towards Z5050BT or Kenwood DDX917s and Morel Maximos nalang kung hindi sulit yung Tempos unamped. Depends how lucky / rich I feel on that day.
    Bali normally what will happen, correct me if I'm wrong...
    Replace HU - pag may harness, just plug and play.
    Replace Speakers - Use stock wiring, w/ harness
    Replace Tweeters - Tweeters to have their own wires, di na gagamitin yung stock wiring for this?
    Other plans:
    Will move the stock Toyota speakers into an older Toyota.
    Will move the stock 2DIN AVT Head unit into an older Toyota din without an integrated radio.
    Across the board upgrade, and only yung pinaka bulok na head unit and speakers (on a 2003 Toyota) will get stocked for future/spare use hehe.
    Yung honda will leave it for now... Ok na sa akin yung Polks + Stock HU. Peg na rin for future reference hehehehe.
    Hopefully we'll get everything done before year end... at least medyo clear na yung steps moving forward.
    Thanks sir sleepcare -- laking tulong talaga hehe.
    Aug 2009
    Thanks sir.
    Will PM you regarding this maybe tonight or tomorrow as i'm leaving the office already... this may make your day boss i assure you
    Other plans:
    If the size is the same with your new and old toyota, this might be feasible..
    Pwede ito actually this will improve/worsen the sound quality depending on the older toyota. If i may, what older toyota is this? Is this a camry?
    I'll answer this kapag nalaman ko na yung "older" toyota. hehe
    Nako... ang mangyayari neto yung newer toyota na paglalagyan ang magiging future reference as ito yung mas ginastusan
    No problem sir. I enjoying helping out as much as i can.
    Hehe ito yung plan sir...
    Currently---
    Fortuner - Stock AVT + Stock Speakers + Tweeters
    2004 LC120 - X9650 + Stock Speakers
    2003 Camry - Stock Kenwood na mapanget at mahirap gamitin + Stock Speakers
    Planning to move the Fort AVT and the Stock Front Speakers + Tweeters to the LC120, dunno lang where I can put the tweeters; X9650 will move to the Camry.
    The next time, pag may newer vehicle for upgrading speakers, the old stock speakers can go to the Camry's hehe.
    Aug 2009
    Quote Originally Posted by mda View Post
    Currently---
    Sabi ko na camry yung tinutukoy mo na "older toyota" boss. I knew it!
    Yung stock kenwood ng camry is i think the silver one with mini-disc compatibility?
    Actually feasible yung plan na transfer of AVT to the LC120 but for the tweeters dyan na tayo magkakaroon ng problema. If you are an "OC" guy, the best that you can do is buy a surplus or brand new pillars from toyota/your known toyota supplier with tweeter provisions. I think later LC120 (pre-LC150) models have tweeter provisions.
    But kapag hindi option yung pillar provision, either bibili ng aftermarket tweeters or not install nalang at all. I think the latter ang mangyayari kasi medyo hesitant ka boss when it comes to splicing. Hehe
    Quote Originally Posted by Sleepcare View Post
    Hehehehehe alala nyo yung older posts ko...
    Yes, it's the one with the mini disc. Ang hirap gamitin, everything needs to use the circular ring and tatlo lang yung saved radio stations. No aux in either.
    What's nice about this is hindi integrated sa dash... madali lang palitan ehehe.
    Yung tweeters, pansin ko yung LC120 may have some tweeter provisions sa may door... Sa kaliwa ng letter "E" sa link ko sa baba.
    LC120 Door Panel
    I wonder if it will fit there...
    If hindi matuloy yung tweeter installation, will there be a big difference in sound? Diba kapag component speakers, may range of sounds that the big 6.5" speaker won't play?
    Aug 2009
    LC120 Door Panel
    Yes kasi nung bago pa ako dito sa tsikot familiar na yung handle mo kaya naisip ko bigla yung camry
    Sobrang malala yung kenwood na yan sa totoo lang but it sounded ok naman for me. Yan yung kinaganda ng toyota kasi "aftermarket" friendly compared sa ibang makes na kailangan pa ng panels and etc.
    Pwede naman yan but yung tweeters baka walang bracket so no choice ka but to use "adhesive" for that. Or retain nalang totally yung stock LC120 tweeters.
    For me, there is a difference but i can't say kasi i really turn up the treble sa HU kaya i find the need for tweeters.
    Yes kapag component speakers na naka-crossover, there are range of sounds na hindi maplay. Depending on the brand but in my experience, it cuts off at around 2-3k hertz
    I once put my ear to those holes in the door sa LC120... parang walang sound or vibration na lumalabas.
    So yun, parang yan yung plan ko hehehe. Based on checking with some local shops, bumbay unit ata yung mga Z5050BT na tig 25k. The ones with the local pioneer warranty are 35k, with the DDX917 at 40k. At that price, sa DDX917 na rin talaga bagsak ko hehe.
audio set-up for beginners [continued]
