Page 128 of 154 FirstFirst ... 2878118124125126127128129130131132138 ... LastLast
Results 2,541 to 2,560 of 3070
    Nov 2015
    #2541
    Quote Originally Posted by Joke_Serious View Post
    amps lang po ang pinalagay ko kanina sir..audison po ang pinalagay ko tapos ginawang full active na lang po ni jonz ang focal 165f seps ko sir..malinis na nga po ang tunog hehehe heto na po set up ko ngayon sir HU - pioneer avh 595bt, focal 165f full active seps, audison sr4 amps at focal bp20 bomba active sub..NOTE*** di ko po isahang bili yan sir one at a time lang pero nabuo din sa awa ng Diyos
    grats.. ako magsisimula pa lang. buti sa luzon, maraming reputable audio shops, dito sa probinsya namin, ewan ko lang, actually yung magiging installer ko ngaun is recommended by the Focal PH, wala naman siya shop, he install and fabricate word works at home. and actually there is que for his services, i've booked my slot already from a month back and my sched will be this coming 25th.
    Aug 2017
    #2542
    Quote Originally Posted by ikloyputograpi View Post
    thank you po sir..critical stage po dyan sir ang pagtotono..i am lucky lang na si jonz ang nagtono..makikita mo talaga ang mastery nya pagdating sa pagtotono with all the gadgets pa hehehe hindi tainga lang..
    Nov 2015
    #2543
    Quote Originally Posted by Sleepcare View Post
    Sa totoo lang boss never pa ako nakakita ng focal seps na powered by focal amps. Usually audison/helix/rockford ang terno.
    kinda bit worried when you stated this one because i have pre-ordered already the items to be installed on my vehicle, but alas, searching thru FB pages from the reputable shops in the metro, tho its not common, but at least these guys has already installed fpx/fd amps at least once on this following shops.
    (a) JC Car Audio - Land Rover
    (b) Timsaudiogarage - Ranger
    (c) Simplesound - Santa Fe
    (d) Mickey Autosound - Pajero
    To ponder, why these shops not recommend the focal amps, it will be audisons and helix that are always posted.
    Why i choose the focal amps maybe because of their sizes, my vehicle doesn't have that much cargo space compared to other suvs.
    Aug 2009
    #2544
    if in any case i would want to hook up a pair of coaxials with an amplifier, how many channels do i need? is it 4ch also?
    a pair for the woofer and a pair for the tweeters? is this how it works?, complete newbie regarding audio setups, i just don't want to end up paying when its not needed.
    say for example i would want to install a PC 165F a Focal Expert Coaxial having nom power of 70w RMS, with an impedance of 4 ohms. and as per what i've read at Crutchfield, amp should range between 75%-150% of what the speakers RMS is. so tentatively it will be 55w-105w range. so approximately a Helix G4 having * 4 Ohms 4 x 80 will be satisfactory right?..
    this (car audio) is just rocket science for me, no idea from the beginning, awaiting for your inputs guys, thanks in advance.
    4 channel if you need to hook up the coax.
    Channel 1-Left Separates (tweet and midbass then naka-crossover)
    Channel 2-Right Separates (tweet and midbass then naka-crossover)
    Channel 3-Left Coax
    Channel 4-Right Coax
    Yes 80watts per channel is ok na. Actually for me more than enough na yan for "basic" set-up.
    i thought so too, majority of the focal seps are being paired with helix or audisons. i have only seen some post twice from timsaudiogarage being a full focal setup (seps with fpx amps), but then again, so you were saying focal fpx's line doesn't blend well with its speakers?
    I think it boils down to the amplifier characteristic. May sinasabi kasi na "dark-sounding" amps like helix and audison which complements the "warm and bright" sound characteristic of the focal fpx.
    I think yan yung mga owner specified na "one brand" set-up ang gusto nila hence ganyan yung set-up. No problem naman sa focal amps but i think mas better matched lang ang helix/audison.
    Nov 2015
    #2545
    well noted. also in addition if budget permits fpx isn't too bad as well
    Aug 2010
    #2546
    My thoughts for these past few pages..
    On the amplifiers...
    1. To be honest, I am not a fan of Focal amplifiers. This might be strange for somebody with two of them at the back of his trunk but I find them expensive for their performance. I got mine at a great price (people still weep over how much I got them) but at the level of Focal FPP/FPX, my vote would be to go for something better -- something like Phoenix Gold Ti amps. They're not popular locally but maybe Mike still has some on sale in their warehouse and those would definitely be a better -- at the very least, better in brand heritage.
    2. Focal makes great speakers but not so much on amplifiers. Phoenix Gold has a better reputation when it comes to amplifiers. However, Focal's FPS lineup is great like... Genesis Dual Mono great. Somebody learned to make simple amplifiers with beefy internals and Focal got the FPS right. You can view it as a pricey PHP40,000 amplifier but I view it like getting 90% of Genesis Dual Mono's performance at half the price.
    3. Helix makes very good amplifiers that is why I like them over Focal's (at cheaper prices). They're not as well known as their more expensive sibling Brax tho. One of the reasons why they're in-fad now is because.. well, the distributor's doing well in their promotions frankly. It fits what you need in an amplifier: they're small, well-built, and priced well. Many don't know but Helix has been making amps for a long time now and many say that the G series is Dark Blue's successor (Helix Dark Blue 5) which we never really had since first shipment ng Helix Philippines were the H-series and even that was niche.
    4. To be honest, their internals are nothing special at these price points tho. You can go China Php15,000 and have the same performance; it just so happens this has Helix's brand over it. But it's really pretty generic inside (which isn't bad really)
    5. Mosconi Gladen ONE's are cheap like the Helix. But they're nothing special (so are the Helix'es) but I like their price and in the end that's what matters.
    6. If you want an uncommon recommendation, JL XD amplifiers are lovely. It's kinda sad their local pricing is kind of prohibitive but those are excellent amps if you find yourself strolling around in the US.
    On the install..
    1. Expect it to extend a few days. It's rare for an installer to be perfectly on time when it comes to it. Unless it's a simple setup we're talking about.
    On the speakers..
    1. I like full-range 2-ways over tweeter + midbass combo's given less dedication in tuning
    2. It's way way easier to tune a full-range speaker than doing a good transition from tweeter to midbass mainly due to the lower cutoff of the 2" driver
    3. However, a good 2-way done correctly sounds better than a full-range + midbass. I swear those Morel Piccolo's from the Fat Lady were magical and the top end sparkle is something the Bewith lacked
    On pairing..
    1. Unlike many, I'm not a believer in it in a car setting. In home audio, "yes" to a certain degree and "definitely" in earphones/headphones were the driver is direct. But car audio is reflections galore. Your entire curve will change depending on car even with the same gears.
    2. That is why: Buy what speakers you like. For the amplifier, get the baddest one that fits your criteria. As Jeremy Clarkson says: POWAAAHH. Since at the end of the day, you aren't buying tubes. You're buying an amplifier to amplify the sound.
    3. In fact, your goal in car audio is to correct for the room. Everything else revolves around it. I'd take a cheap but tuned system over a non-tuned pricey one anytime.
    On experience..
    The biggest lesson I can say is that: don't fall into the gear trap. Good sound is very subjective; this isn't like camera where a medium-format sensor is technically superior in all aspects. I might have roughly Php300,000 of SRP goodies in my trunk but I really do enjoy streaming Spotify Premium. Purists would scream why aren't I doing Hi-Res but hell.. I'm 100% good.
    Second is that: 98% are content with just good sound.
    I have three systems at home:
    - one that can rival condo units in cost (completely treated, monoblock amps, 6-digit speakers)
    - one is my room system: untreated room, PHP32K Dynaudio bookshelf, a Php25,000 1995 Classe amplifier (srp: 6-digits inflation adjusted)
    - and the last one is a PHP15,000 Klipsch bookshelf powered monitor and a Php5000 10" active Monoprice subwoofer as my computer speakers
    And trust me: the difference in "sound" is huge between them. But I spend most of my time in the last one and I don't find myself firing the first one and waiting for the pre-amp tubes to warm up to listen to Ed Sheeran. If I were to divide my time, it's 10%; 30%; and 60%. While I complain that these Klipsh's vocals are far from the Dynaudio (which I swear are so lovely), I don't see myself chucking them off the window. Way way better than my old Logitech's anyway. I'm very much content with them.
    My next setup will be more simple.
    1. PHP 30,000 on a full-range + midbass in enclosure
    2. PHP 15,000~ 4-channel amp + DSP
    3. #CheapBewithLessons
    *tutituts24
    1. Remember, your biggest sound determinant is the speakers. Spend most of your cash on it.
    2. Keep your subwoofers cheap, speakers expensive, and the amplifier somewhere in between.
    3. So not a fan of generic head units, sorry to say. But I would forgive the sound difference if it gives a better user experience (ex. if it's on Android with a good screen and good screen responsiveness) especially if you're on a budget.
    *gaol
    I'll go for the Audible Physics option of Mickey on the reasons stated on the "speaker" comments.
    And that ends my wall of texts.
    Nov 2015
    #2547
    Quote Originally Posted by jhnkvn View Post
    On the install..
    On the speakers..
    On pairing..
    On experience..
    *tutituts24
    *gaol
    astounding thorough input.. well noted sir.
    Feb 2007
    #2548
    On the install..
    On the speakers..
    On pairing..
    On experience..
    *tutituts24
    *gaol
    Long read, but very, very informative! Thanks for the suggestions, bro!
    Jul 2003
    #2549
    ano po suggestions HU na kaya:
    1. apple carplay and android auto
    2. phone mirroring?
    3. standalone navigation like maps.me or osm
    4. tv plus ready
    5. backing cam ready
    6. can be paired to another bigger monitor in a van.
    7. front and or rear (backing cam?) dashcam real time display?
    8. has good built-in sounds na will just upgrade stock speakers to better ones not larger speakers
    it will be for a van
    thanks
    Aug 2017
    #2550
    On the install..
    On the speakers..
    On pairing..
    On experience..
    *tutituts24
    *gaol
    Sirhow i wish maaudition ko ang tunog ng set up mo hehehe sana mapagbigyan mo ako..
    Aug 2010
    #2551
    You can send me a PM on when you'll be dropping by Banawe. I usually frequent the Starbucks there near King Chef.
    Aug 2017
    #2552
    very much willing po sir..maraming ty
    Apr 2014
    #2553
    Interested on this too sir! Will it be okay if I PM you too to audition?
    Sep 2006
    #2554
    On the install..
    On the speakers..
    On pairing..
    On experience..
    *tutituts24
    *gaol
    Which 4 channel amp with dsp would you recommend that has a budget of 15k? Thanks
    Aug 2017
    #2555
    Goodmorning sirs..i think this would help to other audio set up beginners (like me). I have some converted music videos for pioneer avh 595bt (hindi ko lang po alam kung magplay sya sa other pioneer HU) in higher audio and video bit rate..most of my converted music videos are as follows..boyce avenue, wish 107.5, new rnb and millennial song daw hehehe at marami pa..at still downloading at converting pa din..PM nyu lang ako kung gusto nyu magcopy..di naman siguro ako OT dito as this will also form part of the audio set up natin mga sirs hehehe..
    #2556
    I finally got the chance to upgrade the sound system on my mux. Installed are GroundZero gzic 16x in front but replaced the tweeters to RE and a Phoenix gold basscase8 amplified by a GroundZero Mini Four and powered by Pioneer x5750bt. Thanks to Maspro Enterprises for the great install!
    Aug 2009
    #2557
    Quote Originally Posted by beni23 View Post
    Boss how much yung damage?
    #2558
    I paid 55k all in all. Nabili ko yung mga gamit sa Warehouse sale ni sir Mike except the headunit, panel and the wirings. [emoji4]
    May 2010
    #2559
    kumusta po yung PG basscase 8? kaya ba ang cabin ng MUX?
    hinde po ba bitin? salamat po.
    Aug 2010
    #2560
    *Joke_Serious and babybackrivs
    Sorry for the late reply. But sure, I'll send you a PM with my number on it. Just hit me up if you're gonna drop by as I hang out often there.
    *mortis
    There is none I believe. I think China branded amplifiers like SoundMagus has tho as that price point. Alternatively, you can just purchase them separately. I believe LightningLab DSPs go as low as PHP5,000. Fingers crossed nalang tayo sa quality but I'm not a believer of "expensive" DSPs either. In fact, US-site DIYMA has loved miniDSPs in their builds since 2007 and the HK-based DSP provider really does provide cheap processing (they've recently grown and branched out tho)
    *beni23
    How much yun GZ mini amp? :O
audio set-up for beginners [continued]
