Results 1 to 10 of 3070
    Dec 2007
    Quote Originally Posted by battouter View Post
    i bought the car used from a friend, and it was kind of setup already but i didn't really bother with it. It already had a tweeters, subwoofer and an amplifier (see pic) and it is using the stock HU which is an Alpine CDE-9852. I'm just looking for something not expensive but sounds good.
    Sira na ba yun previous speakers mo kung bakit gusto mo sila palitan?
    What's your budget or how much are you willing to spend?
    Oct 2009
    Quote Originally Posted by markygy View Post
    sira na daw according sa electrician. both lower half of front speakers were badly corroded. the rust ate through the bottom half of the speakers where the the bottom half of the cone has become detached from the metal frame. i have no idea how much speakers are as i have never needed to replace any from our previous cars. how much would speakers like the one that the car came with would cost these days?
    Dec 2007
    Mukha nga kaiangan nang ma replace iyan luma. While you're at it with the electrician might as well check the other gears that needs replacement or repair as well. Those old ES series components you have cost around 3,800-4k bnew.
    Where are you from? Maybe we could recommend a reliable car audio installer near your area so you can check the prices and relay your queries.
    To have an idea re. speaker prices visit the mickey's autosound website.
    Oct 2009
    4k seems fair... visayas kase ako, i just need info on what brands and models i should shop around for.
    Oct 2007
    Sirs I just bought an AVT underseat slim sub, had it installed by a local auto shop. It sounded good naman po. Lately i think i need to adjust/tune the subwoofer for better sound quality but i do not have any idea how to adjust its phase and frequency and the HUD settings like the high and low pass filter. Meron ba dito parang template nalang to follow your figures/settings, i am
    After sound quality lang po..(isuzu mux ls-a and the head unit they told us -avt din po. Thanks in advance..
    Aug 2012
    How much and where did you buy the AVT underseat slim sub?
    Oct 2007
    Quote Originally Posted by red_one View Post
    I forgot the exact price, i think that was around P9,000 more or less, bought it from an Iloilo based auto shop.
    Dec 2007
    Quote Originally Posted by hugobo View Post
    Any chance you could bring it back to the car audio shop where you had it installed and let them adjust it for you? Wala kaseng one setting fits all po.
    Anyway, you mentioned phase settings. Dalawa lang naman ang setting niyan, either 0(zero) or 180degrees. I suggest you play around with it. The correct setting will be the one that gives you the impression that the bass is coming out from the front dashboard. If you can not tell the difference or if the subs is installed at the front seat or front passenger seat then there's no need to adjust the phase since the subs is already located at the front.
    Your active type subs already comes with a low pass filter. Meaning no need to set the active low pass filter on your HU (provided your HU has this feature).
    With regards to the cut off frequency. I suggest you start with 200hz then slowly turn the knob down (to a lower frequency) until you hear that the subs together with the other speakers blends together nicely. Meaning neither the subs or other speakers stands out. There is a good chance that you will need to adjust the gain settings of your amplifier as well when you do this.
    If you feel that it's quit complicated then I suggest bringing it the nearest car audio installer and have them adjust it for you.
    Oct 2007
    hi Sir Markygy, thank you for the time. Yes, the HU has this feature, High Pass and Low Pass and the choices are as follows: LPF - "55hz"; "85hz"; "120hz" "through" HPF - "62hz"; 95hz, 135 hz, "through".
    i am planning to bring it back to them however my sched been too tight lately, again, thank you and my apologies for this "ignoramus queries" really appreciate it..
audio set-up for beginners [continued]
