Results 171 to 180 of 3070
- Feb 2011
- 47
March 20th, 2011 03:28 PM #171hi everyone!!! i was just wondering i have some old school pioneer amp model gm2200 and gm1000. i dont know thier power range. my question is it possible to bridge this amplifier and power a 300rms pioneer 12 inch subwoofer??? reply would really be appreciated!!!! thank you very much and more power!!!!
March 21st, 2011 11:57 AM #172
- Feb 2010
- 55
March 29th, 2011 10:01 PM #173Advise lang sa mga newbie, hindi lang dapat brand and quality ang considerations in setting up your sound system. maganda, maayos at branded nga seps, amp, head unit and sub kung hindi naman marunong or maayos magtono yung shop or installer, useless din yung mga yan. Afaik, mas ok kung audiophile yung magtotono to achieve and unleash the potential of your audio.
- Mar 2011
- 7
April 4th, 2011 09:03 AM #174Mga sir nagpakabit na po ako ng morel maximo and 12" earthquake subs enclosed sa sealed box na mga 1 cubic feet. Yung ampli dapat V12 kaso pumalpak kaya papalitan siya today. Ano po ba marerecommend niyong amp na maganda na susunod sa price ng V12? thanks!
April 4th, 2011 09:36 AM #175
- Mar 2011
- 7
April 5th, 2011 12:00 PM #176
April 5th, 2011 05:26 PM #177
upgrade mo na sagad sir, yung hi volt na kunin mo, 2volts pa rin ang 5350 e, 2pre-out nga lang to, bali yun lang ang nadagdag, bass/treble pa in, konting difference lang po ata sa price e, kung ma upgrade ka rin lang, at least 4volts na and 3preouts, para po di sayang.
April 5th, 2011 08:13 PM #178
Sir magtatanong lang po, i'm planning to setup my car audio with 2 power amps, isa pong 4 channel for front and rear speakers and 2 channel bridgeable 760W x 1 (4Ohm brigded) for subwoofer (10" DVC * 2 Ohm 350W RMS or 1200W Max)
Sir ang tanong ko po ay yung magiging power supply ng dalawang amps? direct po ba ito from the battery or may iba pang power supply na kakailanganin? hindi po ba magkaroon ng concern sa power requirement ng dalawang amplifier, knowing that it will eat lots of power when it's ON. di ba magdidiskarga ang baterya sir? TIA po..for any feedback and suggestion.
April 6th, 2011 09:53 AM #179
4ga power cable po, direct from battery of at least 80amps fuse in line near the battery, of course that system draws a lot of current so when playing, always turn on your engine to stabilize your current, i also recommend additional of at least 2 farad capacitor near to the amp for additional support to your system and get the best performance of sound even in the long run. You will be needed also a 1 in 4 out distribution block for splitting the power wires easily.
- Mar 2011
- 7
April 6th, 2011 09:17 PM #180
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
