Results 31 to 40 of 3070
October 17th, 2010 11:13 PM #31
- Feb 2010
- 55
October 17th, 2010 11:21 PM #32di ba gusto mo may sub na boom boom power? pano mo ipapagaya setup ko eh hindi na kakayanin ng budget ko sub. though yung magiging setup ko kung sakali, may provision na sa sub. laki ng kailangan money eh. pero baka maworkout naman ni jeff na baguhin yung ibang brand especially sa ampli para bumaba ng konti yung price. in case baka january na ko magpalagay ng sub. unahin ko na muna seps and amp.
October 18th, 2010 02:40 PM #33
* ekiboy
eto po yung specs nung setup ko;
HU- Pioneer KEH-P6950
Pioneer CDX P1250 12 disc CD changer
Seps:
Front- Focal Polykevlar 165K 6.5" * 80w nominal power input 180 max
Rear- MBQuart discus series 6" * 100w max
Amps:
Rockford Fosgate Punch series 200 a4
4x50w for the front & rear seps
Audison LR 180M
180w mono for the subs
Coustic XM1e Active Crossover
Audison cables (RCA & power)
Stinger Fuse and grounding blocks
October 19th, 2010 11:22 AM #34
makikiraan lang...
tanong lang...
ilang watts ng speaker ang pwede sa car stereo walang ampli?
ano marerecomend ninyo na speaker para dito? ok lang ba na mataas ang wattage? at anong klaseng speaker?
yung medyo ok ang tunog pero hindi naman tunog lata..
hindi ko kailangan na sobrang gandang sound quality.. basta lang hindi masakit sa tenga at may konting bass lang..
salamat...
October 19th, 2010 11:46 AM #35
kahi gaano kataas na watts pwede sa HU powered speakers. minimal lang naman requirements ng HU.
i could recomend ryan audio, pioneer, or targa. it depends on your budget talaga. targa is the bang for buck speakers pero better pa rin quality ng ryan audio and pioneer.
are you going for seps or coax type of speakers? stock ba hu? if yes, mas ok palitan muna HU. kahit stock speakers gaganda tunong kung upgrade ng HU.
- Jan 2010
- 28
October 19th, 2010 12:11 PM #36kind sirs,
will the system below be a good basic SQ set-up?
Amp: Powerbass ASA600.4
Seps: Firland EV602 (then later move to rear side doors when add'l budget is raised for a Cadence ZRS-6K)
Sub: 1pc Powerbass PS10 (or any recommended 10" sub)
would like to retain the JVC KD-BT22 unit on the car. i believe this will go around the range of 20k-down. will this work sirs appreciate your inputs.
thanks in advance.
October 19th, 2010 12:59 PM #37
ang lakas ng amp mo sir! hehe
yung mga speakers have the risk to be overdrivien. subs at 225 rms and 65rms seps. kaya output ng amp would be 400 rms bridged.
i would say na change the amp to rockford fosgate p500-4. sakto lang lang sa subs (busog) then change the seps to DLS R6A. 160 rms nito. clear and crisp sound.
October 19th, 2010 01:50 PM #38
October 19th, 2010 02:15 PM #39
seps: specialize speakers for high and midrange. separated by tweeter and mid range. meron itong crossover to separate the two frequencies.
coax: combination of high, mid, and low range in a single speaker. usually mga 6X9 sa rear ito ginagamit sa sound setup. for stock kahit yung front speakers coax din.
ibang speakers? subs na lang: for low deep bass.
October 19th, 2010 02:34 PM #40
For modern cars... people forget that coolants have a lifespan and that they need to be replaced. ...
