Results 1 to 12 of 12
    Jul 2005
    baka nadiscuss na to dati tamad lang ako maghanap para san yung stuffings na nilalagay ng iba sa loob ng sub box? pra ba mas buo ang tunog ng sub nila? tsaka what's the best amps kung ang ipluplug mo lang e isang sub? sensya na tamad lang maghanap
    May 2004
    ano yung sub? ilang watts?
    Jul 2005
    http://www.crutchfield.com/S-JfNA2EG...0&I=500SWR1042
    something like this. isa lang kelangan ko kasi gagawa pa ko ng custom sub box e..
    May 2004
    laki nyan gwaps ah. pang SPL na rin. kuha ka ng amps that can power 500++watts RmS * 4 ohms. 700watts RMS i think will be fine(wag lang underrated). usually yung mga 100+w per channel na 2ch amp pag mono e abot na sa kanya. mine an old school RF200ix produce 500w x 1 at 4 ohms(although running ako ng 8 ohms sa sub). di ako masyado updated sa mga newer amps pero i think jbl/alpine are "best for a bang" brand. good luck. btw, me space pa ba sa 350Z mo for a big box?
  5. #5
    anong stuffings? you mean brackets? para mas structurally sound ang box?
    Alphine or JL amps pwede diyan bossing. look for mono amps yung up to 1ohm stable.
    Jul 2005
    meron pa naman... gagawa na lang ako ng sub box kahit di masyadong malaki... salamat sa mga advice. siguro in about 3months tapos ko na yung audio set up ko
    ILD yung stuffings e yung parang mga bulak na nilalagay sa loob ng sub box
    May 2004
    tingnan mo na rin yung recomended volume nung sub at baka sobrang liit magawa mo.
    Jan 2003
    ...ahhh yung fiber fill ata yung sinasabi mo. nabasa ko dun sa KAC it makes the sub perform as if its in a bigger box.
    edit:
    eto pala, c/o silver:
    "fiberfill is usually used as some sort of a dampening material...it will also make the speaker think that it is in a bigger box by dispersing "standing waves". "
    Quote Originally Posted by gwapito69
    gwaps, polyfil or fiberfil ang tawag dun and you need 1.5 lb per 1 cu.ft. of volume, meron nito sa Walmart. Kung isang sub lang gagamitin mo look for a mono amplifer with "class D" it's best for subwoofers and any brand will do.
    Jul 2005
    eto specs ng sub na kukunin ko
    Woofer Size 10"
    Woofer Material KEVLAR-reinforced pulp
    Magnet Size 85 oz.
    Continuous Power Handling 500W
    Peak Power Handling 1,500W
    Impedance 4 ohms
    Number of Voice Coils Dual (2)
    Efficiency 83dB
    Frame Material Aluminum
    Surround Material HAMR
    Recommended Installation Type Sealed/vented/bandpass
    Recommended Cubic Feet (box) 0.6-1.25 cu. ft. sealed; 0.5-0.8 cu. ft. vented
    eto naman yung amp na balak kong kunin. ok lang ba to?
    Continuous Watts per Channel (4 Ohms) 340W x 1; 125W x 2
    Continuous Watts per Channel (2 Ohms) 170W x 2
    Continuous Watts Bridged 800W
    Max Power Watts per Channel (4 Ohms) 280W x 2
    Max Power Watts per Channel (2 Ohms) 400W x 2
    Max Power Watts per Channel (4 Ohms Bridged) 800W x 1
    Number of Channels 2
    Crossover Low-pass
    Amplifier Class and Type A/B
    Low-Pass Filter Variable (50Hz - 300Hz)
    Line-Level Input Yes
    Speaker-Level Input Yes
    Crossover Frequency Range 50-300Hz
    Bass Boost 40Hz, 0-10dB
    Signal-to-Noise Ratio 100dB
    Bridgeable Yes
    whats the difference between class A,B,C,D and channels 2 and 4?
    here's a quote from KAC's Silver:
    Full Range Class D Amplifiers
    how good are these amps? check this out Benefits of Class D http://www.altomobile.com/html/amplifiers.html
    comparative review:
    A Class of Their Own
    do i hear value for money?
    the most power efficient fullrange amp you can ever own with the performance close to amps more than twice it's price
    2 channel is for powering a set or one speaker and 4 ch. is for a set of speakers for the front and rear or one speaker (sub) for the rear.
    Click here for the type of amplifer class.
    http://www.crutchfieldadvisor.com/le...fiers_faq.html
audio set up
