Can anybody recomend a good (but affordable) small subs?
i have limited space as I intend to mount them in the side panels of my Pajero. I can't spare the cargo space kasi eh.
I'm just looking for good sound quality and not too much SPL.
I'm having the panels changed to MDF and the interior walls covered with acoustic foam for better acoustics. The mounting depth is also around 5" only.
ssaloon,san pde ma contact si ben,kasi nadaya ako nung gumawa ng sound set up ko,di ko namn kasi kabisado tungkol sa sounds eh,hingi lang sana ko ng tulong..tnx..
How important is it to "seal" the subs? The subs and the wire terminal did not come with gaskets. Can I use some kind of sealant? Should I remove the carpet under?
IF you are going for the "hard" bass, its really important to have a good seal for the sub-box. Before, I used silicon sealant to plug the small holes and gaps in my isobaric sub-woofer box. Not the most ideal but it works.
