Results 1 to 14 of 14
    I have an Alpine 7930 single CD car stereo and I want to use this as my HU. However, I am having problem with the wiring connections. Wala din akong makita so far sa internet.
    The red wire I know goes to the positive(+) wire and the black one as ground(-) sa battery.
    How about the yellow wire(with a 3amp fuse) that indicates "TO CAR ACCESSORY"? How can I connect this yellow wire to test the car stereo?
    Can I put the yellow wire together with the red wire onto the positive terminal?
    I tried to open the old stock stereo but I can't find any diagram and there's no black/yellow wiring...just blue and red. Try ko din kung my label na TO ACCESSORY sa mga lights pero wala din akong makita.
    Thanks!
    if im not mistaken. if you connect the yellow wire with the red wire you can turn on the HU even without turning the key to acc. if you connect it to the acc you can only listen to the HU if the key is above the acc. better look for the wires in the ignition switch.
    Natry ko na ring i-connect ang red and yellow(together) going to the (+) battery terminal and black to (-) terminal ayaw pa ring mag power ang car stereo.
    Kapag naman iyong yellow wire lang going to (+) terminal and (neg goes to ground) nag spark ang wire.
    I've heard before na dapat oks lang ang yellow plus red. Pero mukhang gusto talaga sa accessory connection(yellow) ng isang ito.
    DIY baby!!!
    my alpine (na 2nd hand cd-ready), the red wire sa accessories switch and the yellow wire directly sa positive terminal ng battery. yellow wire kasi to power the memory of the HU (clock and pre-sets ba). both red and yellow have fuses for protection.
    Looks like this unit(7903 not 7930) needs an amplifier for the power. Nagtanong ako sa mga nag auction sa ebay and they told me that I need an amp to power this HU dahil walang sariling power supply sa loob.
    Check ko nga ang loob ala ngang sariling power supply.
    Any experience with this?
    Thanks...
    I have Alpine 7833, i tap both red and yellow to + batt. and black wire to the ground, nag power-up ang unit. pero kung yellow or red with black lang hindi nag pa-power on. Baka ibig sabihin nila "you need an amp to use this unit", some Alpine car stereo does'nt have a built-in power amplifier, hindi power supply. Kung walang speaker wires ang harness at RCA OUT lang, no built-in amp ang CD receiver. Kung ayaw talagang mag ON baka sira yan.:confused:
    Ang sabi ng ibang guy hindi daw talaga mag power pag walang amp. kaya binebenta din nila ang unit coupled with an amp.
    Eto ang sagot sa akin ng isang ebay seller:
    Black - Ground
    Yellow - Positive battery
    Red - Switched positive
    Blue - Remote to amp
    Line outputs - for amp
    Palagay ko nga may sira ang unit na ito kasi sinubukan ko ang yellow plus red going to the + battery and (-) sa ground pero ayaw pa rin.
    Kung sira, sayang ang pagkakabili ko rito maganda pa naman. Sabi kasi ng nabilhan ko working pullout daw ito sa car niya. Anyways, $1 lang naman bili ko sa kanya so oks lang cguro kung ayaw gumana. Pagawa ko na lang sa pinas ....
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=39755
    thanks
    thanks
    Hehe....$1.00 rin bili ko sa Alpine car stereo sa flea market, may sumpong lang ang CD player.
    hehehe may katulad din pala akong matiempo sa flea market...saan ka bang fm malimit?
    madali yan dre..open mo lang ang unit then soaked mo cotton buds then punasan mo lang cd lens gagana na yan.
    I fixed so so so many cd players already mini/compo/car stereo that I bought...like WAYyyy CHEAP! hehehe na nafix ko using this method.
    pero sa alpine na to mapapahiya yata ako...
    Sabi nung Chicano hindi sya sigurado kung umaandar, binili ko na rin for $1. Hook-up ko pag uwi put CD and test radio, OK naman. Kakabit ko na sa SUV ayaw ng umandar ang CD Player.:confused: :mad:
    Sa Oakland Drive-in (Wed-Sun) ako na punta.
    Nakapunta na rin ako diyan sa lugar na iyan...iyan ba iyong hanggang sa ilalim ng tulay may nagtitinda?
    Or iyong sa isang colliseum ba iyon...i know oakland area din iyon.
    kung hopeless na yan Alpine, benta mo na lang faceplate sa eBay.
    Beside I-880 exit ng High St.;)
    Ah iyan nga iyong fm na napuntahan ko din...
    sayang eh maganda ang porma ng alpine. try ko pa troubleshoot ...
Re: Car Stereo Wiring
