Results 1 to 10 of 10
    mga audio peeps,
    what would you recommend?
    amplifier or equalizer booster
    for my 400W 3way speakers
    salamat po!
    i would prefer the equalizer booster. better way to balance the audio . imho lang. but if my HU has a built-in equalizer (like i have now), i would go for the ampli.
    Quote Originally Posted by zero
    mga audio peeps,
    salamat po!
    Uy! Katukayo! Baduy lang ako dahil may "h" pa... hehehehe 8)
    Anyway, 400W 3way speakers mo...seps ba 'to or 6x9? San naka install, sa harap ba (doors) or sa likod (panel)?
    amp
    amp, the equa can only do so much. the amp is the juice, equa is normally for tuning.
    Feb 2003
    yup...pag mahina tunog go for the amp...pag malakas na pero gus2 mo lang tono...go for the eq
    thanks for sharing your opinions.
    Zhero, sa rear panel ito, 6.5" yung round spkrs.
    ngayon ko lang pala naalala....
    kapag 400W ang spkrs, kailangan ba 400W din ang amp/equabooster?
    ah ok... kaya ko muna natanong kung saan naka-install yung speakers kasi kung mahihilig ka talaga sa car audio, harap na speakers ang mas importante. Imagine mo nalang pag nasa concert ka, kahit yung orhestra type, diba yung mga sounds naggagaling sa harap. Yung sounds na galing sa likod ay usually echo lang. hhhmmm...hahaba reply ko :mrgreen:
    Amp muna.
    Check mo yung nominal rating ng speakers. 400w, max na yan. Yung nominal rating and pwede mo gamiting guage. 8)
    as much as possible.....try to balance your front and rear speakers....it really depends on what you have at the moment.....if you think that balance ang tunog niya pag nag amp ka.....then go for the amp......EQ boosters also have the same effect.....the only difference is the settings.......pero IMHO.......its up to you to decide........:D
    amp
ampli or equa?
