Results 1 to 10 of 10
- Jun 2005
- 35
July 12th, 2005 01:41 AM #1Audio pips, i bought a kicker ZR120 amp a while back and never got around to installing it (was suppose to use it to power my rear fill, but later decided not to have rear fill anymore). Im thinking about just giving this old, but brand new amp to my kid brother, who just recently got bit by the car-audio bug. He started buying his components piece by piece, like most of us did after saving our allowances/salaries, and he already has seps for his front stage, coaxials for rear fill and an amp for the seps. Hes planning on getting (1) JL Audio sub next, specifically a 12w0 or the new 12w1. My question is, will the amp im planning to give him be enough to power either model sub (12w0 or 12w1)? The Kicker ZR120 amps specs are:
4 ohm bridged mono = rms 120
2 ohm bridged mono = rms 180
If not, i may just sell the damn thing. Anyway, hope you can give me advice and thanks in advance!
- Jun 2005
- 35
July 12th, 2005 02:34 PM #3Originally Posted by kewlryds
July 12th, 2005 02:47 PM #4
IMO 12W1 will sound better, and it has more Power Handling capabilities. However subjective naman yan, and its a JL, sigurado akong malambot ang bayo niyan. Get an amp that is 2 or even 1 ohm stable for your sub with at least 200 watts RMS. Look for old school amps -> Soundstream, Orion, Precision Power, Alphine, etc.
- Jun 2005
- 35
July 13th, 2005 12:02 AM #5Originally Posted by ILuvDetailing
- Jun 2005
- 35
July 13th, 2005 03:41 AM #8
your amp is rated at 120watts * 4ohms and 180watts *2ohms. factor in that the zr line is one of those amps that are under rated by the manufacturer...it actually puts out a little more than what's quoted. the subs on the other hand are rated in the 125-150watt range. you're amp is within the ideal power range to drive the subwoofers.
July 13th, 2005 01:01 PM #9Originally Posted by psych_on
JL 12W1
http://www.jlaudio.com/subwoofers/pdfs/12W1_BDS.pdf
Continuous Power Handling = 125 watts
Nominal Impedence = Single 4 Ohms
sorry 4ohms pala yung 12W1
Based on the specs, your amp should be able to handle the power requirements of the Sub.
JL 12W0
http://www.jlaudio.com/subwoofers/pd...2_15W0_MAN.pdf
Nominal Impedence = Single 4 Ohms or 8 OhmsLast edited by ILuvDetailing; July 13th, 2005 at 01:05 PM.
- Jun 2005
- 35
July 13th, 2005 02:52 PM #10Originally Posted by ILuvDetailing
I thought there's only one belt. akala ko drive and timing is the same. Thank you
