Results 1 to 16 of 16
    OK..first things first, i dont have that much budget yet.
    I'll tell u guys the audio installed in my pickup (wag nyo pagtatawanan):
    HU : Pioneer deh-1450 in dash player (i saw an add selling deh-2350 yata..parang mas gusto ko kasi hindi nakakasilaw ang display
    Speakers : Pro-line aura with crossover and baffles na manipis sa likod ng upuan sa rear seats (para konting bass manlang meron). tweeters in front and mid sa rear.
    ...hehe un palang po.
    ano ba dapat ko gawin? para san ba ang amp? hehe pasensya na, super amateur ako hehe :lol: :lol:
    magkano ung "i dont have that much budget yet"? 50 thou?100 thou?1 thou?
    ano gusto mong marinig pa?pangit na ba sa pandinig mo ang naririnig mo ngayon from your set up?
    Glenn,
    kasi pag malakas na ang volume, hindi na maganda ang bass. Buo pa naman kaso parang gusto nang sumabog. Amp ba ang dapat ko idagdag? Also nasisilaw ako sa display nung HU ko, mas gusto ko ung sa trooper namin na 7450 yata un...sarap tingnan ng display :mrgreen:
    ill check it nalang...hirap mag suggest ng hindi ko pa nakikita...
    Oki..thanks! :D
    Feb 2003
    DIY.
    http://www.blaupunktusa.com/install/install_speakers.html
    Feb 2003
    Pioneer Speakers: http://ikesound.com/Prod_Details.asp?Prod_Id=1166
    Sub: http://ikesound.com/Prod_Details.asp?Prod_Id=655
    Head Unit: http://ikesound.com/Prod_Details.asp?Prod_Id=810
    Amp: http://ikesound.com/Prod_Details.asp?Prod_Id=1144
    // just my two cents //
    Quote Originally Posted by Djerms
    Djerms,
    Glenn's right. Pls. let us know how much you're planning to allocate for your sounds, so at least we can have a figure to play around with. IMO, that DEH-1450 will give you the music already, so you can stick with that, although it would be better if you could go 2350 or 7450MP
    for front speakers, separates. if there won't be a way to fit in a sub behind or beneath that rear seat, then you might have to stick with 6x9s for your bass.
    IMm29,
    budget ko for now is 5k palang. Super sorry sobrang wala akong maintindihan. Para saan ang separates? Ang nasa front ko lang po ay tweeters (sa dashboard). Nasa likod ang mid (kasi walang front speakers allocation ang L200 sa front doors). Should I transfer my mid speakers sa front? Magpapabutas nalang ako, watya think?
    5K hmmmm dag dag ka ng konti tapos bili ka ng AMPLI lalakas yung signal mo from the HU papuntang speakers.
    SUPER LAKING improvement na ito compared sa walang AMP.
    yung setup ko e AMP 4 way kinabit lang sa COAX at SEPS yung gitna sa HU pang fill in Oks na para sa akin yung Bass sound medyo me konting bayo na kahit walang subs. hindi sabog yung sound kahit malakas volume.
    AMP siguro 4.5K (yung mga Korea lang ang bilhin mo oks naman un e pero minimum is 4 way wag ka bibili ng 2 way sayang e.) tapos wiring / fuse maybe 800 to 1000 yun so +/- 5.5K (kailangan bili ka wiring para maganda yung pasok ng kuryente at maganda rin yung output ng sound siganal papuntang speakers
    ma sasatisfy ka na niyan maybe for the next 4 months then upgrade ka ng seps after 4 months tapos kung lulang pa subs at amp uli.
    Djerms,
    i suggest you take Rediesel's suggestion and buy an amp first. the 4 channel Taiwan-made Alpine V12s can be purchased for around P4.5K. if the resulting sound is ok for you, then problem solved (for the meantime, that is, until you want better sound, hehehe).
    may i make a suggestion tho? after installing the amp and listening to your system and you realize you want more, try planning your setup in the long term, so you can set the appropriate budget. audition other systems as well, especially those in pickups. good luck.
    ano po ba ang difference ng 2 way at 4 way? ano po ba ang co-ax? ang seps? Waaaahh! di ko maintindihan ang mga to..:lol:
    Meron na pong 2 crossovers ang set-up ko, may baffles sa likod ng rear seats, may mid at may tweeters? kulang pa po ba? Pwede kaya amp nalang ang idagdag wag na ung mga coax at seps (kung anu man un). :mrgreen:
    Nga pala..ive read somewhere na may wattage rating pa ang mga amps, anu ba dapat ko kuhanin? :?:
    2 way ay 2 output, 4 way ay apat output (yung kayang ipower na speakers)
    so mas mura in the long run kung yung 4 way bibilhin mo kesa 2 way ngayon tapos 2 way ulit in the future.
    coax ay 6x9s pareho lang yun. (yung oval shape na speaker na nandun na yung tweeter at woofer pati minsan midrange)
    wattage rating yung POWER na binibigay ng amp papuntang speakers.
    The higher the wattage rating the higher the price (sa mga established brands).
    Pwedeng pwede na amp muna at wirings, pa setup mo lang ng malinis. Next time ka na lang magdagdag pag meron ka ng budget.
    AMP lang garantisadong MA PAPA WOW ka na sa sounds ng pickup mo. lalo na kung naka CD ka.
    *never mind my post, nasagot na po ung tanong ko*
    peace
    Feb 2003
    bakit nga kaya ganon, mr meleagant8??? napansin ko din...
    Aug 2006
    unti unti lng sir mabibigla sa budjet tama try to get muna nag front speakers(separates) aura pwede na budjet seps then isang V12 1507 apatan na para sa front and rear saka na yung sub. pwede na yung mga targa na sub tapos 1 uling 1507 wire mo ng bridged solve ka na jan!!! total ka lng ciguro ng mga 9 to 12 k dipende kung straight b new mejo mataas + 1.5k pa pala sa box
I'm planning to set up my audio...konting tulong pls
