Results 11 to 16 of 16
April 15th, 2003 11:51 AM #11
Djerms,
i suggest you take Rediesel's suggestion and buy an amp first. the 4 channel Taiwan-made Alpine V12s can be purchased for around P4.5K. if the resulting sound is ok for you, then problem solved (for the meantime, that is, until you want better sound, hehehe).
may i make a suggestion tho? after installing the amp and listening to your system and you realize you want more, try planning your setup in the long term, so you can set the appropriate budget. audition other systems as well, especially those in pickups. good luck.
April 16th, 2003 08:54 AM #12
ano po ba ang difference ng 2 way at 4 way? ano po ba ang co-ax? ang seps? Waaaahh! di ko maintindihan ang mga to..:lol:
Meron na pong 2 crossovers ang set-up ko, may baffles sa likod ng rear seats, may mid at may tweeters? kulang pa po ba? Pwede kaya amp nalang ang idagdag wag na ung mga coax at seps (kung anu man un). :mrgreen:
Nga pala..ive read somewhere na may wattage rating pa ang mga amps, anu ba dapat ko kuhanin? :?:
April 16th, 2003 02:26 PM #13
2 way ay 2 output, 4 way ay apat output (yung kayang ipower na speakers)
so mas mura in the long run kung yung 4 way bibilhin mo kesa 2 way ngayon tapos 2 way ulit in the future.
coax ay 6x9s pareho lang yun. (yung oval shape na speaker na nandun na yung tweeter at woofer pati minsan midrange)
wattage rating yung POWER na binibigay ng amp papuntang speakers.
The higher the wattage rating the higher the price (sa mga established brands).
Pwedeng pwede na amp muna at wirings, pa setup mo lang ng malinis. Next time ka na lang magdagdag pag meron ka ng budget.
AMP lang garantisadong MA PAPA WOW ka na sa sounds ng pickup mo. lalo na kung naka CD ka.
- 237
August 10th, 2006 02:02 AM #16
unti unti lng sir mabibigla sa budjet tama try to get muna nag front speakers(separates) aura pwede na budjet seps then isang V12 1507 apatan na para sa front and rear saka na yung sub. pwede na yung mga targa na sub tapos 1 uling 1507 wire mo ng bridged solve ka na jan!!! total ka lng ciguro ng mga 9 to 12 k dipende kung straight b new mejo mataas + 1.5k pa pala sa box
Daming issue ng SU7:grin:
Xiaomi E-Car
