Results 1 to 11 of 11
    Apr 2006
    how can you remove alternator whine? thee's no whine coming out when using radio, cd's or ipod in the aux input but when the dvd player is attached to the aux input, ngkakaroon ng alternator whine lumalakas lalo pag accelerating. can noise suppressors/filters correct this?
    "ground loop isolator" could usually fix this ... however, some purists would object to this solution and would rather fix the ground loop problem with better wiring setup (and more expensive cables)
    May 2007
    Quote Originally Posted by raquino View Post
    use short cables as much as possible with good shields. poor cables pickup the electrical noise.
    Oct 2005
    grounding problem lang yan sir... try to rewire your system. may amplifier po ba kayo? if meron, ang solution ng mga car audio experts is to use thicker wires (power and ground). plus dapat yung RCA cables nakahiwalay sa power cable kasi they might pick up noise pag masyado magkalapit. if all else fails, and/or tinatamad ka na magpacheck ng wiring ng system kasi siyempre kabit-baklas-latag ng wires mangyayari at kawawa naman auto... pwede na ground loop isolator. hth pO!
    Apr 2006
    i'm not using an amplifier. the car stereo cd mp3 player with aux input is wired directly to the oem socket of the starex. the whine only comes out pag dvd player is being used and plugged in the front aux input. pag cd or radio o ipod wala naman ingay. the ground wire is directly grounded to the body na instead of the stock socket. it's true if with amps we need good grounds and monster cables which i have in my other car kaya wala whine. ang problema ko sa van is stock lahat gamit ko with no amps kaya hirap ako isolate where the noise comes from.
    try connecting the ground wire of the dvd to the ground wire of the stereo instead of the chassis ... this should at least lessen the ground loop between the two devices
    Oct 2005
    baka nga yung grounding lang ng dvd player may problem sir... baka di lang masyado mahigpit, manipis, etc...
    Apr 2006
    thanks will try grounding the dvd player with the stereo
    Aug 2005
    Has this problem been solved?
    Jan 2008
    you have alternator whine because you use the DVD players CAR ADAPTOR which in turn results in alternator whine when you Plug the DVD player AUDIO OUT to the AUX Input... electrical loop is inevitable since the DVD player uses car adaptor with 9volts output (the adaptors circuitry is causing the noise)... You can only lessen the noise by re-wiring your DVD player CAR Adaptor to a DIRECT 12 Volts supply (direct from battery) instead of plugging it to the cigarette lighter jack.. or you use a dvd player with 12 volts input.. or if your dvd player has a battery back you use it instead of the car adaptor..
    Dec 2007
    IMO, try mo na lang i-ground nang maigi yung DVD player mo... kung gusto mo, magpalakad ka na lang ng isang wire of ample gauge papunta directly sa negative ng battery... para walang lusot...
alternator whine
