Results 1 to 10 of 16
- Apr 2011
- 27
April 20th, 2011 02:31 AM #1Good day mga ser. I'm looking for an active subwoofer with an extra pair of speaker terminals that would power my coaxials. Budget audio lang kaya ng budget ko and a retired basshead (pamilyado na). hehe. I was checking out v12's and nbn's and found they didn't have any.
April 20th, 2011 08:02 PM #2
- Oct 2008
- 944
April 20th, 2011 10:42 PM #3v12 at avt din hinahabol kong slim active subs. another would be yung nbn na 8" rounded subs. ok din po ba sila sir? kasi never ko pa naexperience. magkano din kaya mga slim active subs nila? thanks in advance
April 20th, 2011 10:52 PM #4
I would also support tsikotshop's comment. Wala atang ganyan best to buy a 4-channel amplifier and use it to power the component speakers (Channels 1 and 2) and subwoofer (3 and 4).
The use of subwoofers is to create bass (you normally feel the "punch" at around 100Hz I believe) and thus, #1 factor is how it displaces air. Generally speaking: Bigger inches, deeper bass. If you're a basshead on a budget, best to look for 8 inchers or 10 inchers. These should provide enough oomph to make you happy on your daily drive.
But seriously speaking, most people will mistake midbass as their "bass". So maybe upgrading your stock speakers to good entry-level speakers would yield a better difference. I have seen people participating in EMMAs with just front-stage setup without the subwoofer and win. So take note of that.
April 22nd, 2011 05:48 PM #5
Active subwoofer like the one can installed under the set can only produce as low as 40hertz, lower than that is not good to them, so don't expect too much bass quality, it was just like adding a midbasses not a subwoofer. Imagine how much airspace you gain at that space, mas malaki pa yung nasa door panel mismo and much stronger, so, if you like space saving but need some bass quality, better buy a good sets of component system and a good rating frequency response like 40hz-22khz, by these, you got midbass, mid range and a tweeter in one package, if you need a good bass, sacrifice some space, .75cuft is not big, but enough air space for the 8" subwoofer.
- Oct 2008
- 944
April 23rd, 2011 12:05 AM #6so you mean hindi maganda mga active slim subs basta below 40hz? hmm.. next time nga na mapadpad ako dun, tignan ko uli ilang hertz yung sa AVT at V12. kung mababa lang talaga then i might go instead na nga lang with NBN na 8" or 10" round subs. ang ayoko lang sa nbn is yung kung saan ko siya ipu pwesto sa loob na hindi halata yet ramdam ko malapit lang sa akin yung bass. wala kasi ako balak ilagay sa trunk
April 23rd, 2011 09:26 AM #7
April 24th, 2011 09:11 PM #8
Don't worry for super low frequencies. Most of the time they're non-existent in recordings unless audiophile reference yan. Look for subs that can play til 50hz and you're pretty well-off. Human hearing's until 20hz, but most bass you typically hear from day-to-day is around 80-100hz If I let a normal person hear 80hz vs 20hz, I doubt he'll "hear" a difference.
- Apr 2011
- 27
April 28th, 2011 04:08 AM #9
April 28th, 2011 09:51 PM #10
Information lang po, speaker Output of the head unit is full range, just that limited in amplification, meaning, its rms power is definitely low because of its size, say it just 25watts rms * 4 ohms per channel. Kaya kelangan mo talaga ng amp if your separates(components) rating is above 25watts pero kaya pa rin naman. Hi pass speaker out is not power output, its a filter for the frequency cut off.
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
