Results 1 to 7 of 7
January 18th, 2007 10:58 AM #1
help naman, my current setup is the following, I need advise sa mga expert kung ano pa ang babaguhin ko kasi gusto yung sound na parang 5.1 chan, tama ba ako.. help naman po
Head Unit
Pioneer 4650MP3
Kicker Impulse power amp IX702
Kicker Impulse power amp IX404
Kicker Impulse crossover
Pioner cdchanger 12 disk , vcd
B/w 4” tv
JL Subwoofer 12”
2 pc Ryan audio front speaker
2 pc MB quart Rear speaker
thank's in advance.
botyok
January 18th, 2007 07:13 PM #2
Not sure about the specs ng HU mo, but I don't think 5.1 channel capable ang Pioneer 4650MP
Dapat kasi, may DD and/or DTS decoder ang head unit or receiver mo, capable of playing 5.1-encoded media (DVD). Since VCD capable lang yung Pioneer mo, then you should upgrade it to a DVD receiver
IMHO, useless ang 5.1 channel sa kotse. Pang sinehan or bahay lang talaga, since you won't be maximizing its full potential. As the driver kasi, off-center ka, kaya you have to adjust pa the settings of each speaker (channel), depending on their distance to your ears. Too much trouble for a so-so experience. HTH
January 19th, 2007 08:46 AM #3
salamat po sa reply Mr Galactus.
lillinawin ko lang po, HU lang po ba ang dpat kung palitan? or the entire setup?
confused lang po.. sana may makasagot pa kasi ding weekened gusto ko na sya ipa setup wala lang talaga ako idea kung ano nga dapat ipalit, baka lokohin lang ako ng mga mapupuntahan ko.
salamat po.
January 19th, 2007 09:26 AM #4
Mas sanay kasi ako sa Home Theater set-ups, but I'll try to answer your question as best I can.
You need to replace your head unit, dapat 5.1 channel capable, yung mga bagong DVD HU ngayon, usually ganun. JVC yata has the lowest price (saw one retailing at 17k), pero marami ring mga Pioneer.
Just look for the DVD, Dolby Digital (DD) or DTS Digital Surround logos sa head unit or sa box, for sure, 5.1 channel yang mga yan.
Tapos you need at least 6 speakers (LEFT front channel, RIGHT front channel, Right Rear Surround, Left Rear Surround, Center Speaker and 1 Subwoofer).
Based on your post, wala ka pang CENTER speaker, so you need to buy it pa. Just don't know kung saan nila ito ipo-position. But let me just reiterate na its not practical na mag 5.1channel sa sasakyan
January 19th, 2007 10:37 AM #5
yep di mo sya maenjoy siguro kase masyado malapit sa tenga mga drivers mo :D
- Oct 2006
- 114
January 19th, 2007 12:26 PM #6botyok, here's what a 5.1 enthusiast basically needs: (pang POGI POINTS ba hanap mo?)
1. 5.1 ch HU (dvd player)
2. 5.1 ch amp (reciever ang tawag sa HT)
3. 5 speakers with relatively same rms and a sub which is the .1 (your rear speakers are better placed near sa roof to achieve clear effects kc kung sa pinto lang di mo sya ma i-enjoy)
AND 4. palitan mo oto mo ng CAMPER, as in malaking van para sulit ang 5.1 setup mo. otherwise, 4.1 will be just fine.
if madalas audio ka lang as in music lang, katunayan a good set of front seps and a single sub setup e OK na. ang rear mo ay filler lang. since, maliit lang ang space, ang "panning" ng sound from left/right front speaker ay parang may center speaker na rin. if your concern is the "dialogue" from dvd, iba syempre kapag may center speaker pero since halos magkadikit nga ang two front speaks mo e ayos na rin yon. unless, of course if you have DVD Audio na gusto mong i-enjoy.
January 19th, 2007 12:44 PM #7
aside from the hardware, the media that you use should be 5.1 capable. traditional CDs are only stereo. You need to have Original DVDs / DVD-Audio / SACD to enjoy a 5.1 system.
high idle RPM at engine start
