first of all, please do away with the text speak kasi ang hirap basahin.
anyway, get seperate speakers (dual cone as you refer to) rather than coaxial speakers (2-way speakers you refer to). they sound much better, better midbass response and humming tweets.
anyway pag yung dual cone po di ba kailangan pa nya ng separate na tweeters ?mid range?
pag naman po 2 way is incorporated na yung tweeter dun mismo sa ibabaw ng cone?tama po ba?
napansin ko kasi dun sa lumang speaker na nakakabit sa side ng ride ko is parang dual cone lang yata !nung nabili ko kasi ride e 2nd hand lang sir tapos di na gumagana yung speaker sa side kaya yun muna balak ko palitan.
so naiisip ko kung 2 way ba o dual cone pa rin ikakabit ko dun?
2-Way, Component/Seperate Speakers - The low's go to the bigger speaker, while the high's go to the smaller speaker.
2-Way, Coaxial Speakers - Still has two speakers for the high's and low's, but both speakers are mounted coaxially.
Dual Cone Speakers - A single-way speaker with two cones to handle the high's and low's.
It's best to use component/seperates as door speakers. Most speaker locations are set low on the door that you might complain hearing the high's when you use a 2-way coaxial or dual cone - because high frequencies are directional. With a component, you can put the tweeter on a higher or better location.
