Results 21 to 40 of 46
    Mar 2007
    Mar 2016
    #22
    I bought a 360 degree bird view camera system, similar to birds view system installed in the TOTL MS and NP300.
    I will install it in my Tucson, for my daughter, seems letting her drive carnival bumpcars in her younger years had affected her driving skills.
    Anybody knows a good installer of this system? Metro Manila area if possible. TIA
    I find this a cheaper and practical safe driving solution than my wife suggestion of putting used tires around the CUV.
    Nag rerecord din po ba yan , just like dash cam.
    #23
    Quote Originally Posted by festacio View Post
    It records 4 sides of the car at the same time. Its an all around car recording dvr.
    Dec 2017
    #24
    Quote Originally Posted by armattv View Post
    This is interesting! So, it functions just like a dashcam. If it is not too much to ask, kindly share the link where you bought it.
    #25
    Yes like a dash cam, you can set the loop recording from 5mins to 15mins. it has a usb hub where you plug in your usb for recording.
    36deg HD Bird View Panoramic System 4 Camera Car DVR Recording Parking Rear View - intl | Lazada PH
    Dec 2017
    #26
    Thank you very much! I just hope that video quality is good, if not excellent.
    #27
    Video quality is good all cameras are clear/sharp except for the front cam. I am planning of replacing it.
    Dec 2017
    #28
    Please let us know what camera will you use for the front one. I'm thinking if it's possible to simply add another camera and attach it to the DVR.
    #29
    I am planning to buy this type of front camera.
    Mar 2016
    #30
    you might wanna check 3 in 1 Car Camera Parking Reverse ... with sensor
    #31
    Thank you for your suggestion but l don't need to have this type of camera installed in front of my car. This is basically used for backing which my car is already equipped with. Besides, this type is not compatible with my module. What i need is a front small camera that will fit between my car's grilles with 4 pin type connector to be able to connect into my existing harness.
    Dec 2017
    #32
    Are you somewhere in Manila? I'd like to see it personally. That is, once you have the complete setup. Someone suggested that I look instead in Amazon's website, although priced at a higher price.
    Sometimes, a dashcam looks good on SUV but not on a sedan because of the way the windshield is slanted.
    #33
    Setup is already completed as per pictures posted. Just need to replace front cam once l receive my order. You dont install anything on your wind shield. Except that if you opt to install the rear camera inside the car back glass instead of above the rear plate number. I am from sucat. I dont bring the suv daily except during coding of my office service vehicle which is during wednesdays. I Work in makati. You can check ebay as well, thought it will take some time for you to receive the item.
    Dec 2017
    #34
    What I meant is the additional dashcam to be integrated to your existing DVR. One more thing, does it record audio?
    Wednesday... that will be tough for me as I'm assigned in Bataan during that day. Thanks again!
    #35
    I dont have existing dash cam. The newly installed 360 degrees bird eye is my working dash cam now. What is installed previously is the back up sensor with rear view monitored on my head unit. Typical for new suv as part of accesories.
    Feb 2019
    #36
    Can I install 360 degree camera system on stock head unit of isuzu mux? What if may TV Plus na nakainstall pwed pa rin ba ?
    Dec 2017
    #37
    Quote Originally Posted by Angel1478 View Post
    I think this is possible as long as you can use the auxiliary connection.
    Kindly check the connection of your TV Plus to confirm if you can still add the 360 camera.
    This reminds me, we haven't finished the installation of the 360...
    Feb 2019
    #38
    Can you recommend me a person who could do this? Please give me his name and number and preferably Quezon City area
    Dec 2017
    #39
    You can get in touch with PeligRacing:
    +639152894590
    OEM installation, guaranteed! Unless you decide to add a dedicated monitor, the placement will be a challenge.
    If only​ the Mazda OEM 360 is sold separately or the one​ made by Hyundai. The one installed on the 2019 Santa Fe is good.
    Aug 2019
    #40
    tanong lang guys. recently nag install ako nang dash cam front and rear camera back up camera. now i plant to transfer the back up rear rear camera sa head unit. puwede kya yun sa head unit nang vios xe 2019 model di ko alm ang head unit specs kasi if may port ba for back up camera. saka anong model yung HU anong OS din. anyone have vios xe. baka alam nyo pa help naman. no pan to change HU kasi din naman gamit masyado ni misis ang madaming apps. tv plus lang daw kabit sa Hu ok na
360 Degree Camera Bird View Car Camera System- Installer
