Results 1 to 20 of 20
    Dec 2011
    I would like to ask the opinions of the gurus here about the 30 Farad capacitor made by
    Boss and Power Acoustik which is available for only USD100! I'am tempted to buy one to
    put in my power hungry amp to replace my 1 Farad Capacitor.
    I haven't found any reviews here yet, so, is it going to be of any help to my amplifier?
    Has anybody here tried it? TIA
    Aug 2010
    Marketing gimmick.
    Aug 2008
    30 farad??????????
    Jan 2008
    baka 3.0 farad yan... a good battery is enough
    Dec 2011
    It is really a 30 Farad Capacitor either made by Boss or Power Acoustik. I was stunned seing that capacitor and can't believe. I want to know from users if the dimming of headlights was resolved after installing without upgrading the stock alternator.
    Here's the specs:
    Power Acoustik PCX-30F
    Height: 3-7/10"
    Width: 9-3/10"
    Weight: 2.5 Kgs.
    24V DC
    Jul 2011
    Quote Originally Posted by palonmar View Post
    Here's the specs:
    Height: 3-7/10"
    Width: 9-3/10"
    Weight: 2.5 Kgs.
    24V DC
    sir tingin ko pang noise filtering ito, hindi para sa dimming of headlights issue
    Aug 2010
    *sigh*
    Alright, let's start with the basics.
    What's your car?
    How old is your battery?
    What's inside (ICE) your car?
    Most people wouldn't worry about dimming lights unless you're doing around 1000W at peak. If you're using a simple setup and your lights are dimming, I assure you that you're already clipping causing the amplifier to spike its load.
    Most of us in this industry view capacitors are marketing gimmicks. For at the price of a branded one, I could throw a few thousand more and get myself a portable secondary battery.
    For what it's worth, do the Big Three upgrade first. It'll only cost a fraction and help your electrical system twenty times better than throwing a cap on it.
    30 Farad? That is a big WOW! Gaanong kalaki iyan? (I may be the one who will be surprised here, given the advances in technology)
    (as a Farad is already a big measure of capacitance)...
    14.9K:kodak:
    Dec 2011
    The car in question here is the Lancer MX 2001 with stock alternator and a Motolite Excel as a battery (about 6 months old). It has Big 3 Upgrade using 2 AWG with no fuse on it. Has 520W RMS consisting of 6X9's and seperates, driven by 600W RMS 4 channel amp. Added a pair of Alpine Type R's subs of 1200W RMS with 1200W * 2ohms amp driving it. When I tried to max it out, when parked and engine on idle, I noticed that my headlights was dimming during hard hitting or low bass notes. My subs haven't reached its full potential and can give more but my alt can't give enough juice. I came to think I haven't got this problem before the installation of my subs, nor any starting problems of my car.
    Then there goes the monster cap, I was thinking.. would it help my amps power demand? Thinking of upgrading my alternator would be the expensive way, if a $100 30 Farad Cap would help that would be nice, but is it? Kung alt lang ang solusyon, turn down ko na lang muna subs at next project na yung high output alternator.
    Aug 2010
    The thing with capacitors is that they're useless if your charging system isn't up to par. In this case, putting a cap there wouldn't make a difference since, to put it bluntly, the capacitor isn't being charged fast enough as it is being discharged.
    Besides, you don't need a monster cap. Rule of thumb is 1000W for 1 farad. Going more is like putting gauge 0 speaker wires in your car -- a complete waste.
    It's a throwup IMO.. a less expensive way is to buy an extra battery. This should allow you longer playing time especially when you're simply parked with the engine off. I also think it would remedy your dimming lights. However, your alternator is faced with another load to charge.. hence I can't simply recommend throwing an extra bat. A high output alternator seems like your best bet here.
    Dec 2011
    Thanks Sir Jhnkvn for the input! Buying a 30 Farad is a really waste of money and misleading. Now I got this conclusion....If the alternator is only rated 12-14 Volts and 80 amperes at peak power demand, then the capacitor no matter how big the capacitance is, it only stores 12-14 Volts 80 Amperes then discharges it when needed. If the Amplifier is pulling 100 Amperes or more * peak power demand during heavy or low bass notes, a capacitor can only give that much for some few seconds! am I correct? TIA...
    Aug 2010
    Nope. A capacitor only stores a very tiny amount of energy compared to that of a battery. They don't need to store alot since their specialty is to provide FAST additional power during the peaks. This is due to their low internal resistance.. in fact, discharging a 1 farad capacitor completely takes the same time it takes for you to blink.
    As a hint on their capacity. Richard Clark wrote a damn long article about capacitors way back detailing how they work. Took me an hour to read and I still don't understand 70% of it. I'm not an electrical engineer so I really don't care. But here's an interesting trivia:
    Check this link: RadioShack #52 272-1127 Screw-Base Lamp 14.4V 100mA | eBay. That's your typical miniature light bulb that we use everytime we get those damned Meralco blackouts.
    In the case of an endurance battle, a 1.5 farad capacitor would power this bulb for 5 minutes. A 20 farad? Maybe around an hour.
    This everyday Duracell battery we use.. would keep it running for 2 hours and 15 minutes.
    Now think about your car head lights and compare that with your car battery... and you should get a rough idea on how small the capacity is.
    Besides, our cars with stock alternators have varying loads. It won't be dishing out 80 amperes at idle.. it probably dishes around 50 amperes. For example: 1500RPM (idle) - 50 amperes, 3000RPM - 70 amperes, 4000RPM - 80 amperes.
    Personally, I try to avoid car electrical system topics since they're a pain to discuss. To be more specific, you need to compute for your amperes. I think this is a good read if you're a beginner to it: Car Audio Capacitors vs. Power Cells - Knowledge Base
    In a nutshell, here's what I think:
    20 farad capacitor - useless for the money. You get the same goodies from a 2-3 farad cap.
    2-3 farad capacitor - might help your dimming issues especially if it only dims from time to time. What I mean by time to time is let's say you inserted Far East Movement's CD there. You played a 2 minute track and it only dimmed for 5 seconds, 5 on each 1second peak.. in that case, it would help. But if you dim for 1 minute and 30 sec out of the 2minute track, give up on caps.
    An aftermarket Stinger battery - would help definitely on your overall electricals but might not remedy your dimming lights issue.
    An aftermarket HO alternator - now that's where we're talking..
    However, I would first like you to check up on your level matching. Did a professional car audio shop do it for you? Which one? Remember that the gain control on the mono amplifier isn't a volume control. It's one of the easiest mistakes newbies commit hence they tend to clip easily. So before you commit yourselves to any of the fixes, check up on your current system first. Throw in an appointment with the car audio shop to check on your battery and alternator's condition to make sure while you're at it.
    Aug 2010
    Aug 2010
    For some reason, the detailed post I typed yesterday was "for moderator approval" and ended up not being posted at all. WTF is happening to Tsikot >_>
    Aug 2010
    I'll keep this short nalang ;) and in bullet format since I'm a bit annoyed how my previous post didn't post properly.
    A capacitor isn't known for its massive capacity to hold joules but rather its ability to discharge quickly. How quick? A 1 farad cap would discharge itself faster than a kick drum beat.. or around half the time it takes for you to blink your eyes. We're talking about milliseconds here.
    As for capacity. Think of your regular flashlight you use during brownouts. Try to picture the lightbulb.. now a typical 1.5 farad capacitor has enough power to power that bulb for around 5 minutes before giving up. A 20 farad capacitor would last around an hour. Your typical 9V Duracell battery would power it for 2 hours and a half. Now if you think of powering a light bulb using your car battery... you should know more or less how long it'll take
    The dimming of the lights is caused by your voltage dropping from the typical 13-14V to 12V which is battery-territory. Let's say in a perfect scenario where your alternator is outputting 80A and your amplifier is drawing 100A continuously, kahit maglagay ka capacitor.. it's useless since your charging system can't keep up. But if your normal amplifier is drawing, let's say, 50A on average and reaches a peak of 81A in one second (causing your charging system to dip into the battery territory since the alternator cannot provide the output) then capacitor would do its work in providing the extra 1A. But if the capacitor is continually being emptied and it isn't finished charging, it's pretty much useless and presents to your alternator another load to "charge" up like your battery.
    The first I would suggest you do is make sure you're matching levels correctly. The subwoofer amplifier's gain control is not its volume control. I've seen alot of newbies turn their gain all the way up, clip the amplifier then kill the sub. Dimming of the lights is a symptom of clipping since clipping wildly increases the amp's load beyond its normal operating output.
    Now if you're sure you're good, ask your suki car audio shop to inspect your battery and alternator to make sure they're not faulty. (It's very rare but at least you made sure right? Rather than scooping up a HO alternator only for the guy to tell you your battery's the culprit).
    Solutions to your light dimming and what I think is the outcome.
    1. 20 farad capacitor - waste of money.
    2. 2-3 farad capacitor - might help if your scenario's like the one above. If you're dimming for maybe 5 seconds out of a 2 minute Far East Movement track, a cap might help. But if you're dimming for minutes... it's hopeless.
    3. New primary battery - might help.. but I'm running stock Hyundai batteries. I'd say isuki mo muna yun Motolite Excel batteries mo since it's only a few months old. Changing to AGM Stinger batteries would improve your electricals though ;)
    4. New secondary battery - it won't solve your light dimming and presents another load to the alternator. It helps in extending the time you can jam while the engine's off though.
    5. New high-output alternator - it's the sure way.
    If you did the Big Three procedures using 2GA wires. Don't let others fool you that you need 1/0GA wires. Gaano ba kalaki alternator habol mo? If you're eyeing the 200A HO alternator, by all means go for 1/0GA. But if it's around 120A, 2GA suffices na. Heck, my Big "Two" (since 2/3 procedures done na saakin) uses 4GA wires and comes factory-stock.
    Aug 2010
    EDIT: I'll keep this short nalang -> In the end, I typed and ended up with a long one. Forgive my fingers. Haha...
    Dec 2011
    That's a very informative input sir jhnkvn, everybody in this forum will benefit from that. I like reading and a long one is nice to read.
    I used to be listening to Bass Music/ Sounds as others may call it, like Bass 305, Bass Mechanic and the like. There are bass tracks that delivers heavy and low bass notes during the whole duration of the track and so a capacitor like you said cannot give any help to my system. Even though I'am using a 1 Farad Cap, my headlight tends to dim and my amplifier tends to clip during those periods, a description of what you said. The capacitor got no time to recharge but to be discharged and so becomes another load to alternator.
    I've googled about the Deep Cycle Batteries like Stinger, Optima etc.. I don't know how much they are selling those in audio shops, maybe even more than my Excel. Is it true that DCB's produces less current than the standard Lead Acid Batteries because it has less surface area than LAB's? Also, DCB's can survive to be drained multiple times while the LAB's will be damaged if discharged completely. I don't know if that info is correct, here's the link:Charging System Basics
    Based from your input, it seems I don't have to replace my Motolite Excel and a need for a capacitor if I have an ample power supply coming from the alternator. I guess 110A-120A would satisfy my ampliers power demand. May I ask sir if you have any idea how much it cost? TIA
    Aug 2010
    As for the drained multiple times, that's true. AGM batteries can be drained hundreds of times as opposed to our standard dry lead cell batteries. That's why it's a horror for us if we completely drain the battery of our Motolites
    Starting batteries have high ampere ratings for sudden surges (ex. starting your car) but is relatively poor in overall capacity and quickness (they have high resistance from what I believe). Besides, AGM batteries charge faster for what it's worth. For SPL applications where the system is being played loud, having a better battery like Stingers would be beneficial.
    A very good beginner read on this topic is Optima's FAQ page: Optima Battery FAQ - Frequently Asked Questions or if you prefer shorter but informative reads: How To - Car Stereo - Amps, Alternators, and Batteries: Upgrading Your Electrical System
    Price Guide (just so you know):
    An Optima Yellow-Top retails around 12k
    Stinger SPV44 is around 10k
    Motolite's at 5k
    As for aftermarket HO-alternator prices, I go no idea what's the going rate. I've never inquired after all... . However, some shops offer brand-new HO alternators as it is while others simply take your alternator and change out the internals. With the latter being the cheaper option. From my memory, a branded brand-new HO alternator at around 200amps will retail around 30k (you can then further discount this)
    Dec 2011
    If that is the case, maybe I will just upgrade my existing alternator and let them change the internal. There are alternator shops near may place, I hope there's HO alt that can fit to my Lancer or know how to upgrade my stock. Anyway I can save some money for that upgrade. thanks for the advise.
    Mar 2004
    the best would be to install a second battery and upgrade the alternator... the30Farad cap is useful for spotwelding capacitor bank
    a capacitor is charged quickly as it can be discharged...it stores charges that is released whenever the voltage falls.... 1farad would be enough for "peaks" and for smoothing out the noise in the electrical system
30 Farad Capacitor
