DVC subs only allow you to have flexible wiring capability since you can wire them at 2ohms, 4 ohms and 8ohms..
do not connect this where in a single DVC sub was connected to a 4channel amp at bridged, the setup was channel 1&2 was bridged then connected to the Sub at 4ohms then channel 3&4 was also bridged and connected to the same sub on the other side..
your amp will overheat and your sub will not play properly..
