how do you find out if the 2nd hand sub is still ok? secondly, I have a friend selling his v12 amp. MRV 504 for 2500. If I'm going to use this to power S8L5, will this be enough? I've heard that v12's are kinda weak especially in powering kickers. Heat is also something...
check the terminals of the speakers. minsan kasi lubog dahil sa handling ng previous owner. ganon nangyari sa binili kong kicker impulse amp na 2nd hand. di ko napansin na lubog into the board yung terminal. it cost me 1.7k to have it repaired.
ssaloon, what do you mean lubog into the board? how much did you get your second hand impulse amp?
afrasay, I thought about the muffin fan...but I'm kinda afraid of having 2nd hand amps since its really hard to check the condition of the electronics in the amp..
got my impulse for 4k. dapat aligned yung terminals sa labas ng amp diba? yung kabitan sa speaker wires. pero yung akin, slanted inward sa amp. yan yung pinaayos ko.
sometimes risk mo na din yung 2nd hand na amp apecially v-12 pa yan. i had this problem with the v-12 and kicker subs madali bumigay yung amp and nagkastatic agad kaya dinispose ko agad. try mo na lang kung maganda pa tunog but personally may trauma na ako in buying 2nd hand low end amps. kung kicker or rockford pa yan baka pwede pa
