do u guys have any idea how much are these.....??/ tnx...
yup, around that much and be ready to spend another 20k at least for a good amp to power that baby :shock:
if the amp would be a jl 500/1 , then expect spending around 30k for it...oh plus the installation and woodwork and wirings...
ang mhal hehehe magkanu kaya pag sa sates ako pabili bka mga $400-500 lng kya? ang mhal sbra hehe
the 13 w7 is around $700 ata sa states... tapos add the taxes(customs and importing duties, sales tax depending of what state) applicable)...wheee!
while the jl 500/1 amp is around $400-450 sa states... and then again add the taxes(customs and importing duties, sales tax depending of what state) applicable...
*fyi, i got these prices from http://www.uscaraudio.com
so prices may vary...
also, products are very heavy...so add the applicable fees for their weight...
good luck on your purchase... :lol:
meron pa kyang nabibiling jlw6 dito? mag kanu kaya isa 12'? brand new
not sure...better ask around...
w6v2 sigurado meron...
yung 12" w6v2 is more or less 23k...
it is hard to find the first version of the w6, especially brand new ones. though JL has released the w6v2. it has the new look already. autoplus carries the product. they would cost you around 20k+ if i'm not mistaken.Originally Posted by thug_989
JL Audio 13.5 W7 - $ 800
JL Audio amps - pretty much a dollar per watt .........
bitin yun 500w sa 13w7. better get the 1000/1 which goes for 40-50k also. check that sub n amp 80k na. peak is 2000w. recommended continuous is 1000w. or get a high powered amp at 4 ohms - which can be run/stable in a 3ohm impedence. 3ohms kase yun w7's. say for example an amp at 800wX1 at 4ohms it will be 1200w at 3ohms when you connect it to the sub.
check with a+ audio or jetcar. from what i've heard next year Q1 pa darating.
ok na ang 500/1 na JL Audio para sa 10 W7 , kahit 10 " lang not bad for sub
na parang dalawang regular 12" woofers ang performance .
tama, bitin 500w sa 13w7. JL 1000/1 and kailangan. yung (2) 12w7 ko tama lang yung 750-800w bawat sub. Pero mag-upgrade ako para 1000w each sub.
