Results 1 to 10 of 36
September 16th, 2008, 07:35 PM #1
HOW TO: Change ashtray light bulb and fuse
Hi to all! I recently noticed that the service light sa ashtray ni Vanzie is not functioning. Meron na po bang nakapag-palit ng ilaw and fuse sa front ashtray?
I checked the manual including the fuse layout pero
Calling DIY kings help po Thanks in advance
September 17th, 2008, 07:21 AM #2Verified Tsikot Member
- Jun 2006
- 254
Re: HOW TO: Change ashtray light bulb and fuse
Ate Jaaaannnneeee,
Usually bulb lang yan kasi sa wiring diagram ang interior lights naka series sa isang fuse so pag bigay ang fuse hindi lang sa ashtray ang mapupundi. Usually either parang fuse type or twist off ang bulb kayang kaya mo yan.
Jun
September 18th, 2008, 08:51 AM #3
Kooooyyyyaaaa kamusta ka na??? Long time no chat.....i know naman super busy ka lately, same here kaya di na rin ako nakaka-online madalas. istorbo talaga itong trabaho hehehehe
Mamaya I plan to inspect the ashtray sana tulad sya nung sa ref na iikutin lang yung bulb. Napansin ko kasi late pm na kaya di ko na nasilip tapos day off pa ni vanzie kahapon.
Read yung fuse layout sa manual wala naman nakalagay na ashtray...nearest na nakita ko is 22. CIG 15 A - cigarette lighter haaaayyyy
September 18th, 2008, 09:30 AM #4
September 18th, 2008, 09:46 AM #5
September 18th, 2008, 10:01 AM #6
September 18th, 2008, 10:01 AM #7
September 18th, 2008, 10:31 AM #8
If it's not a busted fuse, this is what you can do to replace the bulb:
1. Remove the ashtray.
2. Remove the locking pin of the center panel:
3. Remove the air vent selector cap from the center of the panel. Remove the center panel by placing your thumb against its front side and 4 other fingers on the top side of the ashtray well, then pulling it upwards and towards you.
4. Pull out the peanut bulb:
Parang malaking Christmas Light lang daw iyan, just pull it out of its socket.
5. Replace it, and replace everything in its place... Oh, the locking pin should be in this position before re-inserting it in its place behind the ashtray:
After inserting it, push the center pin in.
HTH...
September 18th, 2008, 06:07 PM #9
Prenster thank you so very much! naka-abot ako up to sa point na matanggal ko yung knobs ng thermostat, fan, air intake eto mga pics:
1. removed ashtray and poked center clip
2. Removed thermostat, fan and air intake knobs
am not sure if kulang ang power na ginamit ko but hindi ko mabunot ang front actually, applied gentle touch takot kasi baka may mabali na clip .... then the rain poured.....itutuloy ko operation kay vanzie pag wala ulit si boss hehehe!!!
I tried the lighter and it worked pati yung modulator ok naman so if nag share sila ng fuse it means the fuse is OK....
September 18th, 2008, 07:11 PM #10
Goo gone or pwede oil. Babad mo lang para lumambot and mawala yun stickiness Sent from my...
Removal of Rain Visor and Chrome Door Handle and...
