test
Page 1 of 14 1234511 ... LastLast
Results 1 to 20 of 273
Thread: E10 and Toyota Avanza (Vanzie)
  1. #1
    Join Date
    Post E10 and Toyota Avanza (Vanzie)
    Hi guys earlier I posted a posted a question re. E10 sa kabilang thread. Anyway, I wrote an email to TYT Philippines re. this matter and share ko lang yung response nila:
    Dear Ms. ***********:
    Thank you very much for visiting our Toyota website! We truly appreciate your interest in our products and services.
    Generally, all Toyota vehicle model year 2004 onwards with Electronic Fuel Injection (EFI) except 7KE and 1RZ-E engines can readily accept the use of Ethanol blended in gasoline, up to [a maximum of] 10% by volume or E10. We discourage the use of Ethanol in all carburetor-type engines in cars, as vapor lock may occur. This will make it difficult to start the cold engine in the morning.
    Please bear in mind that, pure alcohol's calorific value is much less than gasoline's. This means you would use a little more alcohol, compared with gasoline, to get the same power / performance. Under normal conditions, this may not be a problem since we are using only 10% Alcohol and 90% Gasoline blend for E10. Its lower price is offered as an incentive.
    Please buy E10 only from reputable gasoline stations and dealers. Alcohol tends to absorb water from the atmosphere, transport barge, underground storage tank, etc. and if proper handling during gasoline product transport and storage is not done, you may fill up on E10 with high water content. The water may damage your engine and corrode parts. You may want to inspect your fuel tank for water accumulation after some time.
    Kindly do not hesitate to call our Customer Assistance Center at (02) 819 - 2912 should there be additional inquiry (ies), email correspondence is also welcome.
    Thank you. Our best regards
    _______________________________
    Joanne Rellores
    Customer Service Associate
    TOYOTA MOTOR PHILIPPINES CORP.·MARKETING DIVISION· VEHICLE SALES DEPARTMENT· CUSTOMER SERVICE SECTION· CUSTOMER ASSISTANCE GROUP
    Makati Office 31st Floor GT TOWER INTERNATIONAL, 6813 Ayala Ave. cor H.V. Dela Costa, Salcedo Village, Makati City 1227·Email cac2*toyota.com.ph
    Contact +63.2.819-2912 ext 8092·Fax +63.2.858-8040 to 41
    HTH
    Last edited by russpogi; July 23rd, 2008 at 04:56 PM. Reason: added quotes, removed members name on attachement for security purposes...
  2. #2
    Join Date
    Nov 2006
    Unhappy Re: E10 on Vanzie
    Too bad that I just read this a couple of weeks ago . . .
    The primary reason E-10 ethanol gas is harmful
    is because of it's alcohol/ethanol solvent and water-absorbing qualities.
    E-10 is also inconvenient because the shelf life of only 2-3 months.
    Ethanol (ethyl alcohol) has several chemical properties and effects which render it to be incompatible with engine parts and vehicles -
    Alcohols are water soluble, attract and absorb water/moisture, solvent, cleanser and cleaner, drying-agents, de-greaser...and more
    Many motors, especially older engines, are constructed with parts that become very brittle over time and cannot withstand the effects of alcohol. When E10 gas is used, the engine components can disintegrate and clog the engine with sludge and grime, causing the engine to "lock up" and seize. When this happens, often the engine cannot be fixed and must be replaced.
    Ethanol's effects vary depending on the engine type, model and year and type of fuel system, (Carbureted, direct-injected, 2 stroke or 4 stroke).
    Marine engines are probably least compatible with ethanol-blend fuels. Aircraft agencies ban alcohol-blend fuels and are exempt from using E-10 and E-85.
    Gasoline absorption of water is problematic (gas becomes contaminated and must be discarded).
    Operating an engine on an alcohol content that is too high (over 10% for E10), will cause engine damage and poor performance.
    http://www.fueltestkit.com/ethanol_problems_damage.html
  3. #3
    Join Date
    Nov 2006
    Exclamation Re: E10 on Vanzie
    As a precautionary measure, below are some suggested list.
    Precautions For Use of E10 Gas
    1. Test gas for alcohol presence and to assure it is below the legal limit of 10%.
    Gas alcohol levels above 10 percent can cause major damage to most engines.
    Many pumps do not label when alcohol is added. Inexpensive portable Alcohol Fuel
    2. Replace the gas in your fuel tank at least every 2-3 weeks.
    The shelf life of E-10 gas is only 3 months (90-100 days) under ideal environmental conditions
    3. Know the specific fuel laws for your state.
    Many states still do not require the labeling of E10 gas at the pumps. View state ethanol labeling laws here: http://www.fuel-testers.com/state_gu...anol_laws.html
    4. Check your owner's manual for fuel type recommended.
    Older engines (prior to 1998) and several luxury vehicles do not permit the use of alcohol fuels. Many lower-priced and high mileage automobiles experience performance problems and part damage from the use of E10 gas.
    5. Prevent external water and moisture (high humidity) from coming in contact with E-10 gas.
    6. Ethanol-blend fuels will lower MPG in most engines; Fuel efficiency can decrease by 2-40%.
    Maintain your engine to provide the best possible fuel efficiency. (Inflate tires, keep tuned, etc.).
    View more information on fuel efficiency and mpg of E-10 gas.
    7. Chose an octane level above 91, for an added level of security when purchasing E-10 gas,
    If water contaminates (WC) your gas, the fuel will dilute and the octane level can drop up to 3 points.
    8. Avoid all fuel additives and fuel system treatment products that contain ethanol or are alcohol-based,
    Most octane boosters and fuel system cleaning products contain alcohol.
    9. Become familiar with symptoms and effects of "bad gas", often caused by too high alcohol levels of gas.
    Symptoms include varied engine malfunction including stalling, hesitation during WOT, smoke released from exhaust, clogged fuel filters and carburetors, damage to fuel and VRO pumps and pistons, disintegration and dissolving of engine parts (especially rubber and plastic), drying-out of parts (hoses), and more.
    10. Save money - Contaminated gas can not be restored to the original composition.
    No miracle product exists that will effectively prevent all water absorption or safely repair phase separation (PS) of gas.
    11. Frequently check gasoline tank for signs of Water Contamination (WC) and Phase Separation (PS).
    Two or three distinct layers will be seen after WC and PS occur.
    12. Check the engine warranty for details and consequences of alcohol fuel use.
    Most engine warranties exclude repairs caused by the use of fuel containing a high content of alcohol.
    13. Install a water-separator filter (10 micron or better),
    14. Store E-10 and E-85 ethanol gas in clean and dry tanks.
    Fuel discoloration indicates gas contamination, often caused from the release (cleansing) of rust, dirt and sediment from the gas tank walls.
    15. Properly discard any fuel that appears to have gone bad.
    16. Keep your engine well tuned and lubricated and follow the manufacturers recommended maintenance schedule.
    Replace parts that are not resistant to alcohol,
    Plastic and rubber parts and hoses are most vulnerable. Fuel system and pumps, piston and carburetor and timing may need changes to be compatible.
    Older engines often contain parts not designed to resist ethanol/alcohol.
    17. Be aware that "private" gas pumps (EG. marine refilling stations) are not required to follow the same laws that pertain to public gas stations.
    18. Airplanes (all aircraft) are exempt from using ethanol blends and all alcohol fuels.
    19. Many types of engines are not designed for the use of alcohol fuel. This may include older cars and outboards, lawn and other small gas-powered equipment.
    Only during the past 5-10 years, have the manufacturers' re-designed engines, when necessary, to be compatible with E-10 gas.
    20. Consider purchasing an E85 Flex-Fuel vehicle.
    E85 compatible engines contain parts specifically designed to withstand alcohol's negative effects, which will dramatically decrease your risks when buying E10 gas.
  4. #4
    Join Date
    Dec 2007
    Default Re: E10 on Vanzie
    Woah! I'm not going thru all this trouble and sacrifice peace of mind...
  5. #5
    Join Date
    Jun 2006
    regular user of E10 on my Avanza. Ok naman no problems, dont notice if FC is lower. Always stuck in traffic so really poor FC.
  6. #6
    Join Date
    Sep 2005
    just started using Shell's e10 (93 RON) since june. for me, nag improved yung FC ko from 9.5 to 10.02 km/L. Last week, I have just pumped Petron's e10 (95 RON). Will keep you updated since 2-3weeks pa ako magpapa-gas ulit.
    btw, my vanzy is purely (90%) city driving.
  7. #7
    Join Date
    Quote Originally Posted by juanarodriguez View Post
    does this mean using e10 in the long run will be more of a bane rather than a boon?
  8. #8
    Join Date
    Cool Re: E10 on Vanzie
    Pardon my ignorance but I have always been puzzled why, of all substances, alcohol has to be blended with fuel when it has so much risk when used in the long run?
    The benefits are seem to be always outweighed by the cons so why take the risk?
  9. #9
    Join Date
    double post
  10. #10
    Join Date
    well if you read between the lines what the email says can be summarized into two words "Caveat Emptor"
    [SIZE=2]
    caveat emptor (kah-vee-ott emptor) Latin for "let the buyer beware." The basic premise that the buyer buys at his/her own risk and therefore should examine and test a product himself/herself for obvious defects and imperfections. Caveat emptor still applies even if the purchase is "as is" or when a defect is obvious upon reasonable inspection before purchase. Since implied warranties (assumed quality of goods) and consumer protections have come upon the legal landscape, the seller is held to a higher standard of disclosure than "buyer beware" and has responsibility for defects which could not be noted by casual inspection (particularly since modern devices cannot be tested except by use, and so many products are pre-packaged).
    [/SIZE][SIZE=2]source: http://legal-dictionary.thefreedicti.../caveat+emptor[/SIZE]
    well E10 is relatively new here in the Philippines...when LPG was introduced here ganon din naman mixed reaction....I remember a friend telling me to choose petrol stations located sa area na hindi binabaha, etc. kasi may possibility na pumasok sa tank yung water and other impurities...if that is the case then pati yung mga existing unleaded/premium petrol available in the market eh nakakatakot din gamitin
    hopefully in the future when auto manufacturers develop new cars they will take into consideration adding more safety features or whatever para sure na if we use E10 or other petrol we don't need to worry about impurities damaging our cars.
    Eh wondering lang po, meron kayang mga gas station dito sa pinas that closely monitor their tanks, or take petrol sample from their tanks several times daily to monitor the quality of their products?
    sana may makadevelop ng "fuel dispensers/pumps" that will display the water, particulates level, etc in realtime, yung kita while nagpapagas hehehe...
  11. #11
    Join Date
    Dec 2007
    well if you read between the lines what the email says can be summarized into two words <b><i>&quot;Caveat Emptor&quot;
    Tama, pero hindi kagaya ng ethanol, ang LPG conversion walang ganun kasamang effect sa makina. (yata, hehe). Pero ako, hindi mixed ang reaction ko. Ayaw ko talagang mag-take ng risk. Sa LPG ako nagdadalawang-isip pa. hehe.
    Tama ang friend mo. Yung L200 ko, nadale na sa ganyan. A few days (weeks?) after this certain Shell gas station experienced flooding (this happens a few times every year, i think), nagpakarga ako sa kanila. After a few days, pumapalya-palya na ang diesel engine ko. Then it happened: ayaw nang mag-start. I had to have it towed back home and then towed by the mechanic to his shop the day after. Good thing hindi naman nasira ang makina. Never did go back to that Shell station. Matagal na rin naman ang rumors na mandaraya sila, but that experience broke the camel's back, so to speak. BTW, nagpakarga ako ng diesel, punong-puno yung 1Gallon (3.78 liters) container (ng coolant) dun sa kabilang Petron, umapaw pa nang kaunti, pero siguro wala namang isang kutsara ang natapon. 4.81 liters siya!!! Siguro I'll have to go back to the suki at ipapafull refill ko din para consistent ang observation. Dati kasi, pinasakto ko lang sa Php250, pero nagkasya ba naman ang 4.55 liters sa isang 3.78-liter (dapat) na container! I'll get back to you guys on this.
  12. #12
    Join Date
    Quote Originally Posted by puroy View Post
    antay ko ito... considering to use e10 din kasi
  13. #13
    Join Date
    Dec 2007
    Quote Originally Posted by 71204 View Post
    BTW, kagabi, sa balita sa TV, meron daw plans to provide E85 (!!!!) in the near future. Kinilabutan tuloy ako... E10 nga lang, may danger na sa moisture damage, gagawin pang 85% ethanol?!?! Yikes!!!
  14. #14
    Join Date
    Quote Originally Posted by woohoo View Post
    i heard from an insider ng seaoil na ilalabas na nga nila ang e85, and that was weeks ago. in fact, according to him, sen. zubiri's ride runs on it already.
    if this is the case, dapat maglabas na ng FFV's (fuel flex vehicles)
  15. #15
    Join Date
    Considering the cleaner burn and less environmental impact, as well as the substantial 2-peso difference in price of E10, there just may be a benefit in using this. We are all wary of the potential adverse effects, but this is new technology, and perhaps some of the hesitation in using E10 can be attributed to the human nature's inherent resistance to change. I just got my vanzy from the dealer yesterday, and I still can't make up my mind if I should load it up on E10 and reap the benefits or suffer the consequences. More personal experiences from E10 users would be more than helpful.
  16. #16
    Join Date
    Dec 2007
    Quote Originally Posted by Dr Nitro View Post
    FWIW, I am not resistant to change, in fact I welcome it. I am just being wary of the dangers of using ethanol... kung perfectly safe lang yan, why not, at least tipid pa, right?
    (smile)
  17. #17
    Join Date
    Dec 2007
    (smile)
  18. #18
    Join Date
    congrats on your new vanzy Dr Nitro join po kayo ng ACP
  19. #19
    Join Date
    i am not an avanza user, but i've tried E10 lots of times.
    what i would suggest is for you to:
    a. load up on regular unleaded gas
    b. empty up your tank
    c. load up on E10
    check the difference in acceleration and fuel consumption.
    my experience is that FC is around 20% lower. acceleration is the same.
  20. #20
    Join Date
    Aug 2008
    My Avanza goes 13kms per liter of unleaded gasoline on city driving, and 15-16kms per liter during out of town trips. I also use it mostly in the city. Can this be attributed to the periodic maintenance I get from Toyota?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
