test
Page 21 of 29 FirstFirst ... 11171819202122232425 ... LastLast
Results 401 to 420 of 574
Thread: Avanza Tires and Rims
  1. #401
    Join Date
    Default Re: Avanza Tires and Rims
    hi All, my two cents worth on Avanza ride comfort...
    While you do need to maintain correct tire pressure (32psi-front & 36psi-rear, per sticker on driver side door) for ride comfort and fuel economy, the real cause of complaints on overall ride comfort can be traced to 2-factors...and these are vehicle pitch and roll.
    Pitch is the car's front and rear up and down movement. While roll is the car's left to right, side to side movement. Pitch and roll are very noticeable on AUV's and SUV's because of the higher ride height and shorter wheelbase as compared to sedans.
    Now, the Avanza having a higher ride height and a short wheelbase, you would normally expect a bouncier ride. This true even for Fortuners, Innovas, Adventure, Crosswind,etc..
    I used to own a Mits Adventure GLS Sport before and it is much more bouncier that the Avanza.
    The important thing is to understand the limitations of your vehicle and drive within these...i.e. don't drive it at 50kph on a bumpy road...it was not designed for that.
  2. #402
    Join Date
    Quote Originally Posted by ownertype View Post
    bro pa post nung name ng shop at canvassing na din ako for new tires. Ok yung tradein value na nakuha mo for the steel rims. P1k nga lang ang value nun e including hubcaps pa.
    Hi, the name of the shop is:
    DKC Tire Center Corp.
    287A P.Tuazon St. cor 18th Ave.,
    Cubao, Quezon City
    Tel. 421 3549 / 913 8899
  3. #403
    Join Date
    Quote Originally Posted by efpu View Post
    +10
  4. #404
    Join Date
    Mar 2003
    Cubao, Quezon City
    Got it, thanks bro!
  5. #405
    Join Date
    Dec 2010
    mga boss.. ask lang po.. bago lang po kasi ako sa mga gulong..
    ano po diff ng mags at rims?
    para sa akin same lang kasi sila.. pero based on what i have read d2.. magkaiba ata sila e..
    TIA
  6. #406
    Join Date
    Apr 2009
    Quote Originally Posted by wawawoo1 View Post
    TIA
    AFAIK, rim is the part of the wheel where the tires are mounted.
    Mags are wheels made of magnesium alloy.
  7. #407
    Join Date
    Aug 2005
    iyong mags ay short for magnesium (rims). ito ang original na lightweight material na ginagamit para sa rims. tamang term talaga ay rims.
  8. #408
    Join Date
    Apr 2010
    mga sirs... till gaano kalaking gulong pepwede sa VanC?
  9. #409
    Join Date
    Quote Originally Posted by surgeon_jm View Post
    sir, 17 lang max
  10. #410
    Join Date
    Aug 2005
    I think possible nag 18".
  11. #411
    Join Date
    Dec 2010
    salamt po sa response nyu.. :D
    mga bossing.. kung naka 17 inch ka ng rims boss, wala po bang mga problema?
    like sumasabit pag dumadaan sa humps, o pag maraming naka sakay? ..
    tnx po talga mga boss.. big help po tong thread nyu.. :D
  12. #412
    Join Date
    ok lang po ba na ang gulong ko sa harap eh 205/40/17 tapos sa likod naman 205/45/17?
    naka kahoy ako ng lenso sc-01(with 205/40/17 tires) sa nabili ko 2nd hand car. balak ko ikabit sa avanza kaso sobra pudpod na un 2 pcs tires ng lenso(labas na ung thread ba tawag dun?). tapos kung tama nabasa ko, ang katumbas ng stock ng avanza j 14 rims sa 17 ay 205/45/17. since sayang naman un existing na 205/40/17 tires, bilan ko muna ng 2 pcs 205/45/17 un sa likod. later na lang un sa harap. ala po kaya masama effect sa oto un?
    medyo magulo ata post ko, pero thanks in advance sa replies..
  13. #413
    Join Date
    Aug 2005
    better talaga ng mas makapal ang thread ng gulong sa likod kaysa sa harap. kung hindi pa pudpod ang 205/40, ok lang na ito muna ang gamitin.
  14. #414
    Join Date
    kailangan mong naka super low profile na goma siguro niyan kapag naka 18 ka.......at kailangan doble ingat mo sa mga lubak kundi yari ang mags mo.
  15. #415
    Join Date
    Jan 2010
    sir
    may nakita ako rim ganito ang naka indicate...185/40/14.
    pede kaya to palitan ng katulad satin...185/70/14
    pariho kasi 14...
  16. #416
    Join Date
    Aug 2005
    maliit an goutside diameter ng 185/40 kaysa sa stock size na 185/70.
    Iyong 185 ay 185 mm ang lapad ng gulong iyonh 40 at 70 ay 40% at 70% ng lapad ng gulong (185mm). ito ang height ng side wall.
  17. #417
    Join Date
    Jan 2010
    pasinsya na po diko kasi kabisado ang about tires and rims
    diba ang 185/40 and 185/70 ay sa gulong?
    bali ang gawin ko lang eh bibilhin yung rim na 14 (may naka indicate kasi sa rim na 185/40/14). balak ko lang gawin eh bilhin ang rim tapos yung danlup na 185/70 na tires ng vanzy ko yun ang ilalagay sa rim. pede ba to?
  18. #418
    Join Date
    Quote Originally Posted by mada View Post
    pwede...........
  19. #419
    Join Date
    Jan 2009
    Happy Holidays!
    Anyone know which is fuel efficient using tires of 185/65R15 versus 195/60R15? I want to change my stock tires 185/65 to 195/60 but I'm also considering fuel economy.
    Thanks in advance for your help.
  20. #420
    Join Date
    Jan 2010
    195/60/15
    tanong lang mga idol: bakit may color yung inside ng tires nyo, yung drum ng brake? pina paint nyo lang ba yun?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
